I've been looking at some minor updates to this bike. Both front and rear turn signals stick out like sore thumbs. I want to start with the fronts. They currently mount on the headlight ears, which suspend the headlight to the fork uppers.
Wondering if folks can help source two parts:
1. Aftermarket or other-model headlight ears that will fit 37mm forks and do not have that gigantic turn signal mounting point like the OEM units
2. Front turn signal replacement alternatives. The end goal is lower-profile than the OEM, so LEDs are the likely route. I'd replace the rears at the same time if needed and get an electronic relay to make sure it all works.
The ears are the most important bit, as there are probably a million LED options out there. Just need to find ears that actually fit the bike.
