Author Topic: Shop Lighting Suggestions??  (Read 2700 times)
Offline BenelliSEI
  • 1969 cb750
Re: Shop Lighting Suggestions??
« Reply #25 on: November 20, 2021, 01:02:27 PM »
If you want to leave your existing fixtures in place, you can buy a retro kit to convert them to 4' t8 lamps. Then use a direct wire ballast bypass high lumen 4' t8 lamp. Or you could replace the whole fixture with a Lithonia 8' led strip, they make them in a standard or high lumen version.
Sent from my SM-N950U using Tapatalk
Will investigate. Thanks!
Offline chiefum
« Reply #26 on: November 20, 2021, 01:05:50 PM »
Let me know if you have any questions, I'm an electrician.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #27 on: November 20, 2021, 01:49:10 PM »
I ran barrina t-8’s. Here is the part number
They’re like daylight at nighttime! I got enough for 4 rows, but only put in 3.
Offline Prospect
« Reply #28 on: November 20, 2021, 06:42:49 PM »
I must get these. I can't see as well with low light these days. I'm going to get the 4000k (daylight glow) instead of the 6500k. I much prefer the softer light.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
« Reply #29 on: November 21, 2021, 09:14:33 AM »
 I broke the rules and did my led swap wrong. Everyone (box included) said I would need T8 fixtures to put them in. I just put the led's in the T12 fixtures, they fit, I read that the difference is the bulb to reflector distance. I did remove the ballasts in my car trailer just to lessen the overall weight. Every 50 lbs. I can leave out makes it easier to drag up the big hills.
 I can run one bulb per fixture now if I want to because they are parallel wired. My shop has some of every kind of lamp T8, T12, LED with ballast, led without ballast, new fixture led's, led screw in bulbs two, or 3 on a porcelain fixture. It makes a busy ceiling though.
