Hi everyone,
I am experiencing the bike feeling squirrely. I thought at first I had a small leak in the front tire. Immediately got air: front was at about 25, back 27. So I filled them both up, 30 front, 32 back. The unstable feel still continues, and it seems the bike is compressing more on bumps than normal, barely any stiffness, but a spongey feel. I have Bridgestone BT46's, which another shop installed and mounted a thousand miles ago.
I redid the fork seals after they started leaking from when I first replaced them, 5k miles ago. I accidently installed them backwards the second time (I asked another motorcyclist instead of looking it up myself), had to redo the procedure again. However, I remember losing a copper washer for the hex nut on the lower fork sleeve. I believe it secures the damper in place if I'm correct. I also remember losing a touch of oil when filling them up to spec using 10W-30.
The symptoms I'm experiencing seem to be like it's low on fork oil. I also found a bit of oil underneath the speedometer on the front wheel.
What should I do to figure out what's the cause of this? Get new copper washers, drain the fork oil, refill, and reinstall with new copper washers? If that is what I should do, can I do this without fully dissembling everything again (there are no leaks around the seals themselves).
Is this have something to do with steering bearings, un-trued wheels, misaligned wheels, wheel bearings, rear fork neglect, etc.)?
-a concerned rider
