The crankshaft and rods in the F2/3 engine are different from the F0/1 engine, but they will all work in a given bottom end. Be sure to keep the same rods with the same crank, as they were selected by Honda to match the crank lobe weights when the set was spin-balanced at the factory. While swapping them around will work OK, the end result will be much smoother if you keep the original combination.
The F2/3 engines have stronger rods and rod bolts than are found in the earlier engines (and K7/8). This was done partly because of the higher (9500) RPM capability of the cam and valve train. That said, the K0/1/2 engines were used by midget-car racers to turn 12K RPM or more using stock rods (and stronger bolts), so I have nver been sure WHY Honda chose to use stronger rods in the F2/3 engines...
