Author Topic: Oil Clamp Cable  (Read 970 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
Oil Clamp Cable
« on: November 10, 2021, 06:22:56 PM »
Any idea where to get the oil clamp cable; part number 32111-300-000?
I sent it out along with many other things to get vaporblasted and he accidentally lost it.
Does anyone know where to get a replacement? I've scoured the web to avail.
Offline Kevnz
Re: Oil Clamp Cable
« Reply #1 on: November 10, 2021, 07:24:09 PM »
Looks pretty easy to fabricate, bit of panel steel.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline Ellz10
  • ZZ
Re: Oil Clamp Cable
« Reply #2 on: November 10, 2021, 07:49:00 PM »
I thought about that but sure where I could get a small sheet from around here. Most of the stuff around me comes in larger sheets.
I also thought about just getting something in the photo I attached. Find one that fits the diameter of the bolt and call it good.
Re: Oil Clamp Cable
« Reply #3 on: November 10, 2021, 09:52:57 PM »
Make your own in pliable galvanized steel or similar. Easier to attach the neautral switch wire when bending that one
Here a photo.
https://images.cmsnl.com/img/products/crampercord_big32111300000-01_77fc.jpg
I think the 2 others are the same but bent differently. In front drive sprocket compartment and for the ignition cable.
Re: Oil Clamp Cable
« Reply #4 on: November 11, 2021, 12:10:37 AM »
Here is one similar that is still available off a gl1100
https://www.partzilla.com/product/honda/32111-323-000
Offline Ellz10
  • ZZ
Re: Oil Clamp Cable
« Reply #5 on: November 11, 2021, 08:43:55 AM »
Thanks, but I'm not sure if the diameter is the same. It looks similar though.
Here a photo.
I'll have to go check this out!
