Author Topic: Help me identify this CB 750 model  (Read 1789 times)
Offline Teddyhoeg1982
« on: November 16, 2021, 12:16:05 AM »
I paid almost nothing for this bike, but I can not determine if it is a K or F model.
It is registered first time in 1977, but many parts are replaced.
From what I can see, it may be a Harley 16" rear wheel, and front forks also look very wide with a custom triple tree. I can not say if the rear swing arm is original.
Bike has a clean title and papers, but for some reason the papers only say CB 750, not exact model. The serial no. is very hard to read on the frame, since it has a thick layer of paint, but from the papers it is stated as 27xxxxx.
Engine sounds fine and it runs, but with the pod airfilters, it does not pull perfectly. I think the original airbox would fix this and it seems it would run great.
Offline markmyodb
  • Honda owner since 1969. 19 Honda motorcyles, cars, and lawn mowers through the years!
  • Always looking for SOHC people to ride with in NC
Re: Help me identify this CB 750 model
« Reply #1 on: November 16, 2021, 01:12:15 AM »
From the fuel tank & forks I'd say a K7 or K8.
I tell my wife the motorcycles are an investment...
CB550K1: 1975
CB750K6: 1976
« Reply #2 on: November 16, 2021, 01:14:08 AM »
Whats the number on the engine and i will look in id book 4 you
« Reply #3 on: November 16, 2021, 01:36:37 AM »
Is the K7 fuel tank actually different from the F2? Is the K fuel tank wider?
In regards to the forks I did recognize that this seems K, but it could of course have been replaced together with the tank.
« Reply #4 on: November 16, 2021, 01:40:04 AM »
Will check later today when I get home from work
Offline markmyodb
« Reply #5 on: November 16, 2021, 01:51:41 AM »
I think the forks were the same F & K in the late 1970's, but the K Tank was larger and rounder at rear. Similar gas cap. The K model also had that ridge just above the center line, the F did not...as I remember them.
CB550K1: 1975
CB750K6: 1976
Offline dusterdude
« Reply #6 on: November 16, 2021, 02:12:22 AM »
Drum brake tells me k
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #7 on: November 16, 2021, 02:57:16 AM »
Are you referring to the frame or the wheel? Because I think the wheel is a 16" Harley wheel.
« Reply #8 on: November 16, 2021, 03:45:40 AM »
The F model tank is definitely different than the K model tank.
The 1977 F2 had rear disc brake and dual front disc brakes.
The K model in 1977 K7 had wire spoke wheels, rear drum brake and single front disc brake(yours has all of these). Yes someone has changed the triple trees to wider billet aluminum trees(might be harley trees???)
More than likely your bike is a modified K model.
As a reference for you
This first picture is a 1977 K model how it came stock.
The second picture is a 1977 F2 as it came stock.
Offline bustech51
« Reply #9 on: November 16, 2021, 03:50:25 AM »
It was common in the 70's to use the Honda hub assembly and use a Harley rim with different slokes.  That would allow you to have a wider rear tire.   I have that assemly and tire in my shed.
Sent from my LG-H812 using Tapatalk
Offline bustech51
« Reply #10 on: November 16, 2021, 03:55:35 AM »
Carbs look like they came off a mid 70's 750. Not a later '77 or '78 750.
« Reply #11 on: November 16, 2021, 04:04:19 AM »
Do you think the rear hub on my picture looks like the original Honda K7?
Offline bustech51
« Reply #12 on: November 16, 2021, 04:16:31 AM »
Definitely a Honda hub /Harley rim assembly.  I can't say what year hub maybe someone else cam identify it.  On the left side of the steering head (opposite side of the tag) the serial number is stammped into the frame.  May take a bit of GENTLE file and sandpaper use to find it.  Are the fatory side cover tabs still there?
« Reply #13 on: November 16, 2021, 04:24:45 AM »
Yes I will try to remove the paint layer from the serial no.
In regards to the side cover tabs, I will try to remove the current covers and provide a picture.
« Reply #14 on: November 16, 2021, 05:09:09 AM »
What ever it is it has been highly modified. Engine number? 77/78 K rear swingarm. Pre 77 carbs.
« Reply #15 on: November 16, 2021, 06:23:31 AM »
Check that front axle. With those wide trees, there is a huge gap between the fork leg and the speedo drive. That suggests the axle is barely clamped?
« Reply #16 on: November 16, 2021, 06:42:30 AM »
Does indeed look questionable on the picture below - look like the wheel axle may be "hanging" within the homemade spacer.
Will take a look when I get back home today. I am anyway not driving the bike, since it was my plan to find out whether it was a K, and therefore worth putting some money in to making it more original.
« Reply #17 on: November 16, 2021, 08:36:11 AM »
The engine no is CB750E-2738679
« Reply #18 on: November 16, 2021, 08:38:33 AM »
I just managed to find the right angle of light and could see that the VIN is indeed a K frame. So that clears things up for me. Probably i will go at making this bike relatively original and drivable, i have front fork, gauges and other stuff from a K in inventory anyway.
Offline 69cb750
« Reply #19 on: November 16, 2021, 08:55:25 AM »
CB750E-2738679 is a very late K7 engine, near last day.
Please report frame vin
« Reply #20 on: November 16, 2021, 09:04:58 AM »
Frame is 2720131
« Reply #21 on: November 16, 2021, 09:33:34 AM »
A good friend and I have restored 3-4 K7/8 bikes (and scrapped a few). Let me know if you need any parts.
Offline bustech51
« Reply #22 on: November 16, 2021, 09:46:42 AM »
Hey 69cb750, do you keep track of VIN codes?
« Reply #23 on: November 16, 2021, 10:31:12 AM »
Frame is 2720131
Frame is also a K7 [1977].  Here is the model guide...
http://www.sohc4.com/cb750/cb750k/
That front end looks freakishly odd, do you plan to change it?
Offline 69cb750
« Reply #24 on: November 16, 2021, 10:31:20 AM »
You have a question ?
