Author Topic: Tip: One way to unstick a stuck brake piston...  (Read 2870 times)
Offline Doobie
« on: November 20, 2021, 09:14:18 AM »
I've used all sorts of tools and methods to get a piston unstuck. Here's one tip that may be familiar to old pros but I figured it out on my own. IF you have a wheel bearing removal kit, one of the tools will likely fit inside the piston. Snug it up, give it a few rhythmic pulls and it will come out without much trouble.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Re: Tip: One way to unstick a stuck brake piston...
« Reply #1 on: October 11, 2023, 12:14:56 AM »
 I remove the caliper and hang it in a plastic coffee can before taking the hose off. Then pump it out with the master cylinder. Also does a crack job of flushing the master cylinder out.
  I just took a trio of F1 calipers apart using this method, it worked great. I found one nice piston and two pitted ones, ordered some K&L parts from 4-1.
  When I put the brake line back on the bike that I used it didn't even need bled and now has some nice clean fluid in the master cyl. I'll also flush that bikes caliper out when this project gets done.
  I pumped a piston out with a grease gun today, it worked well. The grease gun thread isn't a perfect match but one thread is all you need.
« Last Edit: October 19, 2023, 12:55:49 PM by Don R »
« Reply #2 on: October 19, 2023, 12:56:58 PM »
 I also pumped the guts out of a master cylinder with the grease gun and modified a snap ring pliers to fit in a 750 M/C woohoo. Getting it done!
