You guys never cease to amaze. The pistons I'm using (the semi domed) are infact stamped 392 - they all have a an "A" over top 392 and opposite that 3 have a a "3" and one has a "4". I don't have a smartphone so I found this on ebay . Mine are identical.
https://www.ebay.com/itm/284080745439?epid=1323052181&hash=item4224882bdf:g:3Z8AAOSwL1tfsC10The second set from the '78 F are stamped 410
Thanks all I'm slowing learning more of my old rides history**.
-Kid I hired had some 750s he took apart to fix but didn't. Traded them for some stereo equipment (google that if under 30). Guy who was supposed to pick them up didn't. Mine for $50
-built one from 2 in my basement winter of '93. Friends helped me get it up the stairs come spring (after firing it up down there to check it worked - window open of course)
-blew second gear being stupid at Ride for Sight in '98 and holed the cases when a chain let go in '99
-swapped gears and cases from a doner and flogged it for about another 3 years before it started leaking oil pretty good and it ended up under the bench
-almost 20 years later I'm rebuilding the whole bike from the bare frame up
