I'm going to be installing tapered roller steering bearings and all of the seals in the kit when reassembly day finally comes. They'll need very little maintenance before this bike is parked for the last time.
In the photos you can see the amount of road dirt that got into that bottom bearing, yUck. 'Ol Bob wasn't much for maintenance that required taking anything apart I guess. Plus there were more dirt roads between 1966 and ~1990 when he was riding it, they are much fewer now but I'll find some.
Those forks still pump and rebound, there's old oil in there and not a drop outside. I'll be sure to place my special Honda part numbered special tool clothes-pin on my nose when disassembling and cleaning those.
I'll probably hold off on the horn, as it's not needed right now.
And I may start in on the seat, I've got a piece of foam matting from a VHT member and some adhesive memory foam that I'll be experimenting with, maybe I can find a combination that works for me and looks right.
Other than that I'll continue cleaning up, de-rusting and coating all of the steel and aluminum parts.
I'm beginning to think about fork seals, rear shocks and swingarm bushings.
Hopefully I can reuse the existing fork tubes. Does anyone have any pointers toward finding replacements if needed?
