Author Topic: Braided stainless brake line - where to get supplies?  (Read 1473 times)
Offline timtune
« on: November 30, 2021, 10:11:34 AM »
I'm looking to make up braided stainless brake lines for project and want to source compression fittings and line.
What is the standard line size and where can I get the individual components? Canadian supplier preferred if possible.
Thanks
Offline corky
Re: Braided stainless brake line - where to get supplies?
« Reply #1 on: November 30, 2021, 11:33:45 AM »
Hi there,
Apex brakes has an option to custom make brake lines, and I believe they are located in Canada.  I have had them make some lines for my GL1000, and they turned out really nice, and have lasted 5 years and have had no problems yet.
http://www.apexbrakes.com
I can't help you with the fitting type, unfortunately.
Thanks,
Daniel
« Reply #2 on: November 30, 2021, 03:36:25 PM »
 Most speed shops have pre made hose and fittings, -3 is the size I think 3/8 = 10 mm on banjo fittings. Threads are 10mm x 1.25 or 1.5 I forget which.
Offline timtune
« Reply #3 on: November 30, 2021, 03:38:57 PM »
Thanks guys.
I'm actually interested in line by the foot and separate fittings so I can make my own lines. When they're wrong I want to know who to blame.
Offline spotty
« Reply #5 on: November 30, 2021, 04:26:03 PM »
years ago i had a mechanic friend make me up lines from hose and fittings, they were great ( except i forgot to get the clear hose to cover the amazingly abrasive braided bits ) they fitted exactly and improved the sh1t brakes on the vmax no end
however several months of trouble free operation later i was exiting a freeway at some speed over the limit, went to grab a handful of front brakes at the beginning of the turn and ...nothing - the fitting on one side had unscrewed at the caliper end of the line. brown trouser time. luckily the rear brake was enough to get me out of the situation but not fun. much slower rest of ride home
not saying anyone did a bad job, they had been great for months, but they obviously need checking regularly, which isn't something that normally gets done with pre-made lines
i blame Terry
« Reply #6 on: November 30, 2021, 04:41:45 PM »
Our local supplier for hydraulic, fuel, air, hoses of all kinds crimps them on your old brake line fittings here.
SAE is SAE…..
They can make your oil lines too…
Offline WhyNot2
  • I'm finally an
« Reply #7 on: December 01, 2021, 03:24:30 AM »
ordered mine from 4into1.....!
absolutely satisfied.
Offline timtune
« Reply #8 on: December 01, 2021, 07:27:56 AM »
Was that premade lines or individual components?
« Reply #9 on: December 01, 2021, 12:19:38 PM »
Raymond at Apex. Flawless work. Any colour.
Offline Tintop
« Reply #10 on: December 01, 2021, 12:48:25 PM »
I've made many brake lines (& oil lines) using Aeroquip products, never had a failure.  Any place that makes hydraulic hose will have hose & fittings.  Just Google 'Eaton Aeroquip'.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline desertrefugee
  • Still wanna be a...
  • Phoenix, AZ
« Reply #11 on: December 01, 2021, 03:01:21 PM »
Speaking of sh1t Vmax brakes, I did this conversion this past spring. The Tokico calipers were used on the GEN1 Hayabusa. I also went to braided steel lines at the same time. This is an incredible upgrade. Highly recommended for the Gen1 Vmax.
The shot is just after the install and after I had discovered that cheaping out and not replacing the copper crush washers left me with a leak on one side. Pissed me off enough to order the stainless lines that I don’t have handy photo of right now.
With these calipers coupled with stainless lines, I’ve been practicing my stoppies.
Offline spotty
« Reply #12 on: December 01, 2021, 04:07:45 PM »
thats exactly what i did to mine, after going with 4 piston early GSXR calipers, i also used the busa m/c's after trying the original vmax m/c, works heaps better. the clutch side wasn't necessary but it matches the brake one now
you're right though, a massive improvement along with the 312mm R1 discs that bolt straight on
did you make your own adapters or buy the ones from the guy in california ( mike ? ) who sells laser cut plates that bolt straight up ?
i've often wondered if a busa caliper could be used on the back with one of those adapters ?
i always use new crush washers , rather than buying m/c specific ones bags of alloy 10mm ID washers can be had on ebay for about the same as one proper one from a shop and all the braided lines i've had off ebay have been fine ( as long as you measure the length properly...)
( apologies for the thread hijack )
« Last Edit: December 01, 2021, 04:11:38 PM by spotty »
i blame Terry
  • Phoenix, AZ
« Reply #13 on: December 01, 2021, 04:17:49 PM »
My adapters came from Sean Morley out of Kansas.
With regard to the stainless lines, unless you've fabbed them many times and have the proper tools for crimping the ends on, I would always opt for the professionally made units. Too many horror stories like the above in my mind to risk it. Braking is something I take very seriously. Your brakes are only as good as the weakest link.
Offline spotty
« Reply #14 on: December 01, 2021, 05:08:36 PM »
that's the  guy..( mike from California ?)
the lines i had built had screw up ends, hence why they came apart when I least expected it, they're still in a bag in the garage to remind me not to do that again
i blame Terry
Offline timtune
« Reply #15 on: December 01, 2021, 06:35:01 PM »
I made up lines for my KZ650 i the past from hose and fittings. Worked fine. Just need to line up the bits.
Offline WhyNot2
  • I'm finally an
« Reply #16 on: December 02, 2021, 06:18:01 PM »
pre made, ordered by the set. Like 60 bux,
