Author Topic: Cam followers - hardening/chrome flaking off- Critical?  (Read 1040 times)
Offline timtune
« on: November 30, 2021, 04:45:28 PM »
I've been going through the collection of top ends I have and can't seem to find a set of followers that don't have small flakes of the hardening flaking off - I call them followers - one end rides on the cam and the other on the valve stem. Some have spots maybe 1mm x 1mm or 1mm x 2mm. Some have it coming off the outer edges at the sides.
How critical is this? Considering the number of motors I have with this condition is must be common. Oddly most of the camshaft look decent.
Any advice appreciated here.
Thanks
Re: Cam followers - hardening/chrome flaking off- Critical?
« Reply #1 on: December 05, 2021, 10:08:38 PM »
 I'd be reluctant to use them, especially on a new or especially nice cam. It is possible new type oils were used, without the zinc and cadmium etc. that protect old style non roller cams.
« Reply #2 on: December 06, 2021, 07:41:23 AM »
Thanks
You'll be into the steel in no time even with a stock cam. I have arms that are in decent condition if you want to but them.
Offline timtune
« Reply #3 on: December 08, 2021, 06:03:39 PM »
This oil thing is news to me. How new is new? I last rode this bike in '04.
« Reply #4 on: December 08, 2021, 07:11:31 PM »
 Oil is mostly formulated for emissions engines with roller cams. It may not have much zinc or other soft metals that help protect cam lobes and lifters. Most car engine builders no don't want to sell solid or hydraulic lifters without rollers due to a decades long rash of lifter and cam failures.
 There are diesel formulas or additives made to help these issues. A friend ran 70wt in his alcohol dragster, they added several bottles of axle lube per barrel of oil just to get the zinc and other additives.
 The above is my opinion and not intended to begin an oil discussion, only to explain what I believe may be happening. this began when the automakers went to roller cams.
« Reply #5 on: December 08, 2021, 09:35:56 PM »
Google search on sohc forums + Spectro and you will find oil threads with good information.
Check if cam lobes and bearing surfaces are ok and not grinded/scuffed. That can indicate bad oil flow due to dirt in oil distribution like clogged oil orifices in head, cam holders.
« Last Edit: December 09, 2021, 11:19:22 AM by PeWe »
