Author Topic: CB340F Rings  (Read 673 times)
Offline commander60
CB340F Rings
« on: December 15, 2021, 02:33:56 PM »
Anybody ever use Cruzinimage rings ?
The top two rings have a r on them, does that go up ?
Also one is silver the other is all black, which us top ? Thanks
Re: CB340F Rings
« Reply #1 on: December 15, 2021, 03:34:21 PM »
Silver top, any writting upwards
Offline commander60
Re: CB340F Rings
« Reply #2 on: December 15, 2021, 04:13:56 PM »
Thank you sir
Re: CB340F Rings
« Reply #3 on: December 15, 2021, 04:22:03 PM »
I hope your experience with those are better then a couple of other fella's here on the board. They ended up with some major smokers using them in the little fours. This post is just a couple notches down from yours. Reach out for advice from these guys if needed. http://forums.sohc4.net/index.php/topic,161401.0.html
« Last Edit: December 15, 2021, 04:24:15 PM by ekpent »
Offline commander60
Re: CB340F Rings
« Reply #4 on: December 15, 2021, 05:03:32 PM »
Yeah, thanks I just seen it, I have read stories good and bad about cruizin.
It's a freebe play project, so I will cross my fingers, thanks
Re: CB340F Rings
« Reply #5 on: December 15, 2021, 07:32:23 PM »
Its not the Cruzin kit its the people doing the rebore not listening and making the clearance too big
Offline markreimer
Re: CB340F Rings
« Reply #6 on: December 15, 2021, 08:01:20 PM »
No it’s not. I mean sure it could be in some cases. But I had two independent machine shops verify my piston to bore clearance. 0.0005” or something. Smoked like a coal factory.
Offline jakec
Re: CB340F Rings
« Reply #7 on: December 16, 2021, 01:09:36 PM »
I used cruzin image pistons and rings in my 400F (0.05 over) and no smoke. 1,500 miles. Use a good machine shop
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline markreimer
Re: CB340F Rings
« Reply #8 on: December 16, 2021, 01:13:59 PM »
There are countless positive experiences with the CI 400F and 750 kits. I'm not sure I've ever come across any bad experiences yet.
The opposite is true for the 350F.
If people want to believe every bad 350F experience is due to the machine shop, even when the tolerances are confirmed, well...idk what else to say. I was standing right next to the machinist when I had my clearances checked both times.
Excessive clearance will absolutely cause it to smoke and use oil. Not arguing that. So will junk rings.
