Author Topic: Cb750k5 fuel line routing  (Read 2670 times)
Offline alacrity
  • Ride, Optimize, Repeat
« on: December 03, 2021, 05:02:27 PM »
Carb rack is dual inlet.
I have two new petcocks:
1- single down pipe (installed now - in two photos below).
2- rear side pipe.
There seems to be no good way to route the fuel lines with the T without interfering with access to the throttle stop/idle adjuster (using the petcock with the down pipe). The fuel lines will block any chance fingers will have of getting in there to turn the knob.
The side exit petcock has the fuel line fouling the actuation of the choke, and the only fix I could come up with for that was to twist the petcock 45 degrees clockwise to allow the fuel line to wrap around the top of carb#1 widely enough that it clears choke actuation. This looked dumb/wrong. And it made reaching in and switching the petcock lever very awkward-- not something you want when your bike starts sputtering for lack of fuel and you wanna reach down fast and turn to the reserve.
« Last Edit: December 03, 2021, 11:30:40 PM by alacrity »
Offline alacrity
Re: Cb750k5 fuel line routing
« Reply #1 on: December 03, 2021, 06:38:30 PM »
a clarifying image
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #2 on: December 03, 2021, 08:41:18 PM »
gotta find the shortest path to the bar.
cb750 k6 - ugly
Offline alacrity
« Reply #3 on: December 03, 2021, 11:30:20 PM »
Online PeWe
« Reply #4 on: December 04, 2021, 12:40:42 AM »
How to route the fuel line on a K5/K6 with petcock on left side, 1 fuel pipe has been up on another thread rather recently.
Offline pjlogue
« Reply #5 on: December 04, 2021, 03:22:11 AM »
Odd that your fuel petcock and idle speed adjust are on the same side.  My K-6, stock configuration was idle speed adjust on right, petcock on left. Earlier years (K4?) had the fuel petcock on the right, idle speed adjust on left.  Someone correct me if I am wrong on this.
I suggest you get rid of the braided (shiny black) fuel line and get several feet of the good 5mm Honda fuel line and a 5mm brass "T" and spring fuel line clamps.  Don't use the screw type hose clamps!  Come off the petcock with a short piece of tubing and run it into one of the horz ends of the brass T.  The other end of the horz T will go to carbs 3-4.  The 90 deg down end of the brass T will go to carbs 1-2.  Keep your lines well forward of the idle speed adjust screw.
The braided line I see in your picture is terrible to use in a situation like this.  It is very stiff and will kink easily.  The Honda rubber lines are supple and bend easily without kinking.
-P.
Online PeWe
« Reply #6 on: December 04, 2021, 08:35:39 AM »
The idle screw with its spring can be moved to the other side.
I changed my old K6 carbs when they finally could be reused on my K2 with petcock on the right.
Moved it from right to left when petcock blocked it.
« Reply #7 on: December 04, 2021, 09:09:02 AM »
Oh, I see what's confusing this all up...
First, a bit of history about it: in 1974 when the K5 was first appearing, it got some of the leftover K4 fuel tanks with the 1-outlet, downward-pointing spigot on the left side near where the choke lever is located. The carb rack was still the K4 type with the 2 fuel hose ports (one between carbs 1-2 and another at 3-4 side). Honda 'resolved' this by installing a custom-made tee in the fuel line after the hose passed over the top of the 1-2 side's carb mount hole (ignoring it completely) and almost directly above the 1-2 carb's fuel tee. This made a very short (1.5" or so) fuel hose drop into the 1-2 side, then the hose bent around the back of the #2 carb to run to the opposite side. It was important, in that rig, that the hose to the 3-4 carbs not be too long, or it would create quite a fuel bubble at the highest point, which increased the time needed to fill the 3-4 carbs.
All this worked OK when the speed limits were 55 MPH.
That all changed when the speed limits went back to normal.
When we had to make fuel 'go faster' to the carbs again, this setup wasn't working very well. While the 1-line feed can drop fuel fast enough, the horizontal line to the 3-4 carbs, with its constant air bubble, about the middle of the run, fought the delivery to the far side. The first 'fix' was to get the K4 petcock with 2 outlets, but this puts the rear hose directly over the left-side choke lever (which became the right-side choke lever on some of the 086a carb sets, which aren't all that common). Today those exotic parts are hard to find...
So...Carpy forced me to solve this when one of his customers came to my house with his almost-finished cafe' bike with Carpy tank, which used only the 1-outlet petcock like yours, pointing downward, in almost exactly the same spot yours has. What I did fixed the problem well, but is a little complex and I don't have pix (it was well before my book came out), so I'll attempt to describe it:
1. I came out of the petcock with the 5.5mm Honda hose, over the top of the carb mounting bracket by the 1-2 carbs, then to the space between carbs 2 and 3, back by their airbox inlets.
2. I installed the tee back there, lying flat, by entering one side of it (not the middle of the tee).
3. I ran the opposite side of the tee to the 3-4 carbs.
4. I ran the 'top' of the tee to the 1-2 carbs.
5. I rotated the tee to lie flat down, with the petcock's line running over the top of the 1-2 carb's line so the fuel was always flowing downhill.
In the end, the tee rested sort of mid-air above 2-3 air inlet hoses from the airbox and the 2 hoses to the carb feeds rested atop the air inlet hoses enroute to the carb fuel tees.
I'm sorry I don't have any pictures to show of it. But it resolved the problem and the bike could run to 100 MPH without starvation troubles (which is mighty handy to have on I-25 north out of Denver where it is mostly 90 MPH traffic, and the owner lived in Firestone, north of Denver, back then.)
Another Crapy nightmare forced me into another solution about 1 year before I did the book. This one had a Carpy tank with the petcock outlet coming out directly over the choke lever on the left side, no room to operate the choke if you added a fuel line to the horizontal outlet spigot, and no petcock alternatives (if you're getting the idea that I dislike Crapy parts, you're getting warm...). I made a 1" piece of fuel hose from the petcock, into which I installed some 1/4" copper pipe so I could bend the pipe up and over the choke lever (when it was lifted), then bent another 90 degrees into it to get it behind the carbs from the left side. Then it went to rubber line for 1" to the tee to feed the 1-2 carbs, then hosed over to the 3-4 side. I then had to offset the choke linkage to close the 2-3-4 carbs long before the #1 carb choke plate was closed, and the rider had to cold-start using just cylinder 2-3-4 because it wasn't possible to close the #1 choke plate all the way. (I used to keep notes about these Crapy parts...).  Then, about a year later, this bike came back: the entire lining of the [fiberglass] tank had shed itself into the tank, clogged every orifice in the carbs and fuel lines. After 2 more years, the owner's battle with Crapy netted him a steel tank (unlined, so he POR15-d it FIRST this time...) after I CUT OFF the petcock spigot Crapy had added DIRECTLY over the choke lever, welded the tank shut again, went to the other side to mount a spigot for a petcock with 2 outlets, and mounted the whole tank 3/4" higher (by cutting off and relocating the front tank mounts downward so the coils still had a place to fit under this tank), then made nice, smooth 5.5mm hose transits to the carbs. The bike's been fine since then.
Don't buy Crapy tanks for these bikes, IMHO.
« Reply #8 on: December 04, 2021, 09:14:33 AM »
Honda did some dumb things during the K4-K5/F0-1 transitions of this bike (sorry, Honda, but you know it's true).
One of those was: installing a single-outlet petcock to save 10 Yen because Amaerican speed limits were 55 MPH and didn't need that fast of a fuel drop (and most 750s were sold here) at the same time that the fuel petcock moved to the wrong side of the choke lever. Later the choke lever moved to match the petcock situation, then the petcock moved again. In the midst of this, some bikes got the petcock and choke lever on the same side, like this one. The worst case scenario of this mess was the F0F1 transition, where it is possible to end up with the F1 tank on the F0 carbs, so the fuel hose must run sraight back about 2" to wrap around the top of the #1 carb, then hit the fuel tee, then go to the 3-4 side. Ugly...
Offline desertrefugee
  • Still wanna be a...
  • Phoenix, AZ
« Reply #9 on: December 04, 2021, 09:44:40 AM »
Hondaman, although I have been active onmany motorcycle forums over the years, I haven’t been here for long. But I feel compelled to comment on your contributions.  And I’ll be brief. It seems that every Motorcycle forum certainly has its pillars. It is safe to say that you are one of, if not “the”, pillar of this community. Thank you.
(This particular contribution is especially relevant for me, given that I am slowly trying to finish this K5 I recently acquired. It is a beauty, and has a couple of the quirks that you have pointed out. Thanks again.)
Offline CycleRanger
  • No comment about being an
« Reply #10 on: December 04, 2021, 11:18:11 AM »
Here's how I have the line routed on my K5.
Offline WhyNot2
  • I'm finally an
« Reply #11 on: December 04, 2021, 11:22:15 AM »
Exactly like my K5, but I have a little bit more of a kink at the petcock exit.
That looks great, I'll have to play with mine some more to make it look like yours.\
You did a good job with that.
I also like the clamps on the carb tubes, mine revealing your source?
Like to see pics of the bike itself.
« Last Edit: December 04, 2021, 11:28:44 AM by WhyNot2 »
Offline CycleRanger
« Reply #12 on: December 04, 2021, 11:48:48 AM »
Yeah I spent a lot of time with the fuel lines on my bike as well. No fuel issues with that routing at any speed.
Here's the whole bike. Pretty much stock except for the Kerker.
I don't remember where I got those clamps. Maybe McMaster-Carr.
I probably got the tip from someone here on the forum.
They're marked NORMA 32-50 and they're stainless.
Offline alacrity
« Reply #13 on: December 04, 2021, 02:39:37 PM »
hiya.
thanks for this. It looks in the photo like you are getting the fuel to travel uphill from where it dips down out of the petcock to where it passes between carbs 1/2.   Am I wrong?
Offline alacrity
« Reply #14 on: December 04, 2021, 02:50:14 PM »
Hi.
There is no braided line here. That's smooth/flexible 5.5mm fuel line. It's just not "official" Honda spec.
-P.
Offline alacrity
« Reply #15 on: December 04, 2021, 02:52:40 PM »
Well...  I guess.. I could "just" pull the rack and disassemble it and the reassemble it (again).
<sigh...>
the idle screw with its spring can be moved to the other side.
Offline alacrity
« Reply #16 on: December 04, 2021, 03:32:53 PM »
Thank YOU MARK!
Offline CycleRanger
« Reply #17 on: December 04, 2021, 03:49:42 PM »
hiya.
Yes, there is a slight increase in elevation although it's never caused any problem for me.
« Reply #18 on: December 04, 2021, 06:41:37 PM »
hiya.
Cycle Ranger: your setup is just like they came from Honda in this combination, and is just like I was trying to describe, great picture!
It usually works OK in most places and situations.
When you get to hi altitude, it can be slow to feed the 3-4 carbs on the far side on a hot day. I'm supposing it is because of the slightly decreased air pressures up here and/or the lower temperature of vapor pressure (aka "vapor lock" on old cars with big engines and low hoods, and carbs) when alcohol gets added to our fuels to boot. At least one 750 fellow rider here had to 'help' his K5 when we were climbing Mt. Evans one fine July day: when we got to the Summit Lake (about 11,000 feet) parking area, we laid his 750 way over to the sidestand side (both of us) for a few seconds, then stood it back up. He had clear hoses because he had been 'here' before, and it was easy to see the air bubble in the long hose headed to the 3-4 carb side. Laying the bike way over made the bubble 'burp' into the #4 carb (we think) and he was golden again. He was running 6k-7k in 2nd gear most of the way (his preference) from Echo Lake (10k feet) because he said it had fouled plugs on a previous ride up this mountain and he wanted to keep it cleaned out. But, it was sometimes running low and sputtering (backfiring, really) on the 3-4 side from the constant high revs. This 'burp' maneuver worked, and the line stayed wet all the way to the 14,260 foot top and back to Denver where we fueled back up later on. He mentioned the bubble usually appeared after the bike had been parked long enough to dry out the 3-4 carbs, and then the air bubble would stay until he 'burped' it again. But, he also said that most of the time it had the bubble when he rode around town, didn't cause him any other troubles.
So, I suppose it only goes lean on 3-4 side when you're pressing the flow rate. Makes sense.
« Reply #19 on: December 04, 2021, 06:43:19 PM »
Naw...I've just been around these bikes since they first appeared...
« Reply #20 on: December 04, 2021, 06:48:33 PM »
Those are nice-lookin' clamps! Do they fit right down inside the grooves on the hoses?
Online PeWe
« Reply #21 on: December 04, 2021, 11:10:08 PM »
<sigh...>
You shift side within 1 minute on bike. No need to remove anything more than the idle screw with spring. Carb rack has a threaded hole on both sides.
My K6 carbs have that.
Offline CycleRanger
« Reply #22 on: December 05, 2021, 08:25:57 AM »
Thanks, replicating factory routing was what I was after.
Yes, the clamps fit quite nicely.
« Reply #23 on: December 05, 2021, 09:08:37 AM »
Very cool find! I'm going to get some of those, they have to cost less than the Oetiker aircraft clamps I have been recommending and using ($9 each plus shipping!). When the hoses get old and hard, or if someone gets the new ones from Honda (or someone else), the OD of the hoses at the grooves are now too small for the old clamps to fit, even with new clamps. Then vacuum leaks happen, and troubles start.
« Last Edit: December 09, 2021, 04:54:15 PM by HondaMan »
Offline alacrity
« Reply #24 on: December 05, 2021, 12:36:56 PM »
PeWe idk what your carb rack looks like, but the one that showed up in the boxes I got a year ago that is now part of a k5 motorcycle is in the images below.  The two sides that attached to the actuation rod are 100% NOT mirrored. There is no way to do what you suggested.
I wonder how you could have been so certain?
<sigh...>
« Last Edit: December 05, 2021, 12:42:31 PM by alacrity »
