Author Topic: 550 rear tire size?  (Read 754 times)
Offline vince.whirlwind
550 rear tire size?
« on: December 13, 2021, 04:41:55 PM »
Anyone know the largest size tire I can mount to a ‘78 stock 550 spoke rear rim?
Did a couple of searches for past posts but didn’t find anything. Maybe I’m not using the right keywords
Re: 550 rear tire size?
« Reply #1 on: December 13, 2021, 07:06:14 PM »
In Canada, the best prices have always been from Kenda. Recently, my VERY budget conscious son ordered a set of SHINKOs (I think they are “712” models) for his cb750K. Nice looking and working very well! A 100/90-18 or 110/90-18 should fit nicely on your rim.  I’d use a matching front to go with it. In Canada they sell on line for just over Cdn.$100/ each.
« Last Edit: December 13, 2021, 07:13:51 PM by BenelliSEI »
« Reply #2 on: December 13, 2021, 09:30:17 PM »
A 4.00x18 will fit but a 3.75x18 is a better one
Offline jlh3rd
« Reply #3 on: December 14, 2021, 05:04:04 AM »
I don't think anyone makes a 3.75x18...
there is this.....?
« Last Edit: December 14, 2021, 05:10:34 AM by jlh3rd »
« Reply #4 on: December 14, 2021, 06:55:26 AM »
Only tire dealers (not manufacturers) will recommend tires larger than stock, because they are more expensive, or they have in-stock they want to move.  They don’t give better performance.  And as an added benefit fo dealers, they won’t last as long, either, requiring more frequent replacement.
550 has a narrow rim, 1.85 inches.  Wide tread and narrow mount point pinches the tire where it mounts, resulting in a steep sidewall angle, that allows the tread patch to shift sideways, and makes the bike squirm about in corners.  Not good.  To overcome this condition, the tire pressure must be increased to add sidewall support.  But, over pressure forces the tread crown to balloon, causing the center wear faster and flat spot the crown.  The resulting geometry forces the rider to add more and more counter steer when leaned over as the tire progressively wear.s.  You lose completely the neutral steering characteristics of the CB550.  As you can’t normally find the actual stock 3.75x18, you can order a 4.00x18 for your bike, for a pretty good match for the rim.  And, dealers will do this if you insist.
When you buy tires, make certain the maker specifies proper fitment to your rim width, in order for the tire to perform as the tire maker has designed it.
Also, be aware that stock size inch size tires were 95%-100% aspect ratio.  Metrics in equivalent width measurements will only be 90% aspect ratio, resulting in less overall tire height, that the original bike geometry was not designed to have.
If you want your bike to look good while parked, get “bigger tires”.  If you want your bike to handle well for the duration of tire life, put on the closest to stock size you can find.
So, I put Metzeler 4.00x18 on my 550s, with a 3.25x 19 front.  You can ride them and steer with body lean, hands off bars.  Not that I recommend you do that.  But, riding is far less fatiguing with a bike that handles that way.
Online Stev-o
« Reply #5 on: December 14, 2021, 08:19:23 AM »
I have a 4.00x18 mounted on my 550F. It is an IRC, made in Japan and has been a very good tire at a very reasonable price...
https://www.chapmoto.com/irc-gs-11-rear-tire.html?sku=332-5187&gclid=Cj0KCQiAnuGNBhCPARIsACbnLzpuEv9s3asnV5hVrrzIWQnF0f4Uad-hXL-6W4hZxRR9vIY-LDE9kG0aApbuEALw_wcB
BTW - Who goes to "Tire Dealers" anymore?!  Why waste time and gas driving around, order it online!
« Reply #6 on: December 14, 2021, 08:34:48 AM »
The internet won't mount and balance your tire included in the sales price of the tire.  Dealers and MC shops often will.
« Reply #7 on: December 14, 2021, 08:56:02 AM »
I always go to tyre dealers. Why not? They have all the equipment and especially the rear tyre is a dog to balance. I don't see the fun in wrestling the tyre off and on. What I usually do, is ask to be left alone for 10 minutes after they have removed the old tyre. With a steel wire brush I remove the rust built up in the inside of the rim. Also I wipe the brake drum clean and - if needed - apply a little silicone grease on the cam.
Online Stev-o
« Reply #8 on: December 14, 2021, 09:14:08 AM »
The question was "who goes to TD anymore"?  [not that will internet wont mount and balance?]
I dont, my buddy has a MC tire machine and mounts & balances mine for beer money!
« Reply #9 on: December 14, 2021, 10:00:48 AM »
Ok then, I do.  As they mount and balance the tire, as I wait.  ...And usually for a discount rate.  No beer money required.
« Reply #10 on: December 17, 2021, 01:14:38 PM »
I’ve said this before, but I’ll do it again. Years ago I bought a really good set of tire irons, and a balancing stand (a good one that has all the attachments for accurately truing wheels I build). I mount and balance my own. Saves a ton of money and I know it’s done right.
P.S. get yourself a small tub of the tire lube the shops use. It will last a lifetime and makes the job (both on and off) 10 X easier.
