Author Topic: Help identifying gauge models  (Read 1716 times)
Offline amitr0
« on: December 15, 2021, 09:22:01 PM »
I am having trouble identifying the part number for these gauges.
They are attached to my 550k from 1976, but when i look at the part numbers they all show up in different color combos, like a different shade of green, or red triangular redline area instead of white.
I am confused, are the ones on my motorcycle from a different year, or is there something i am missing?
These are the nippon seiki ones in case that matters.
Re: Help identifying gauge models
« Reply #1 on: December 15, 2021, 09:34:51 PM »
 Your red triangle has faded possibly the faces too, those gauges can also be repaired.
Offline amitr0
« Reply #2 on: December 15, 2021, 09:43:49 PM »
The gauge faces are in excellent condition, unlikely they faded, i have seen similar(slightly different faces before while searching).
How do i repair the gauges, i have searched in usa, couldnt find any decent ones, the one i found wants 400$ for repair
If you have pointers, pleaae let me know.
Offline flatlander
« Reply #3 on: December 15, 2021, 10:54:18 PM »
the green usually does not fade, but the red almost always does. the "white" redline area was originally red on all of them.
you can get parts to repair/restore them here: https://www.cb750faces.com/en/
Offline amitr0
« Reply #4 on: December 15, 2021, 11:32:39 PM »
I have heard about them, but do they simply restore faces or do they also repair the broken clocks?
Offline flatlander
« Reply #5 on: December 16, 2021, 04:47:18 AM »
https://www.cb750faces.com/en/content/7-gauge-restoration-services
you can read there, or otherwise ask them. i guess it depends on the type of repair that's needed.
Offline jlh3rd
« Reply #6 on: December 16, 2021, 05:26:03 AM »
the parts page you are using is for 1977-78 .  Gauges from different years can fit, but faceplate colors are different, but if it doesn't matter to you, use what you want. However, 1976 face plate color is light green.
« Reply #7 on: December 16, 2021, 07:24:18 AM »
Marcel [750faces] can also repair your gauge. But he is in Europe and shipping is very expensive.
You'd be better off finding a good used set. I have a similar spare set but they are ND.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #8 on: December 16, 2021, 01:59:36 PM »
If you want to keep the stock gauges then Marcel is the answer, I’ve used them twice, perfect work. Yes, pricey. If you are not concerned about stock gauges get a used set or reproduction set from Yamiya or David Silver Spares or cmsnl
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline markmyodb
  • Honda owner since 1969. 19 Honda motorcyles, cars, and lawn mowers through the years!
  • Always looking for SOHC people to ride with in NC
« Reply #9 on: December 16, 2021, 04:04:02 PM »
Just to add my 2cents
CB750gages did a great job on my 550K1, and 750K6.
Good Warranty support, even though it turned out to not be their fault.
I tell my wife the motorcycles are an investment...
CB550K1: 1975
CB750K6: 1976
Offline amitr0
« Reply #10 on: December 16, 2021, 04:51:47 PM »
I searched every part website, including the ines you mentioned. i could, there are no reproduction tach i could find. Im case you came across any, please share the link.
Offline amitr0
« Reply #11 on: December 16, 2021, 04:53:06 PM »
Which book is this?
Offline jlh3rd
« Reply #12 on: December 16, 2021, 05:07:43 PM »
the official Honda guide , USA bikes
Offline jlh3rd
« Reply #13 on: December 16, 2021, 05:37:56 PM »
this is an aftermarket speedometer for the K6.... from CMS...they didn't show a tachometer....
Offline jlh3rd
« Reply #14 on: December 16, 2021, 05:41:03 PM »
a honda tach faceplate with a marcel's faceplate below it. There are minor subtle differences, most wouldn't care about
Offline amitr0
« Reply #15 on: December 16, 2021, 07:09:59 PM »
Thanks
Offline amitr0
« Reply #16 on: December 16, 2021, 07:11:48 PM »
Yep, that has been my experience as well. I could not find a tach anywhere. The speedos are available almost in every place
Offline amitr0
« Reply #17 on: December 16, 2021, 07:13:32 PM »
So this red section fades away as badly as mine to almost white? Jesus, almost unbelievable, given that moat honda parts survive the test of time!
Offline jlh3rd
« Reply #18 on: December 16, 2021, 07:34:06 PM »
yep...can't be helped.That honda "red" fades quickly. these are my original gauges. the bike is a 1975, but that red doesn't last..
eh, upside down...but clicks rightside up....
Offline newday777
« Reply #19 on: December 17, 2021, 04:08:11 AM »
It's the paint that doesn't hold up to the 🌞.
Stu
My current rides
Prior bikes....
Offline Kelly E
  • Geriatric Hooligan
« Reply #20 on: December 17, 2021, 10:43:42 AM »
Red fades in the sun faster than any other colour.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline 34barab
« Reply #21 on: December 17, 2021, 02:16:22 PM »
If you decide to get a good used OEM set, I have one with Nippon Seiki Japan on the faces.
And a +1 for CB750 FACES.  Marcel has done two sets of gauges for me, and the results were exceptional.  Yes, it would take a while and be costly, but worth it.
« Last Edit: December 17, 2021, 02:32:07 PM by 34barab »
Current Projects: 1973 CB750K3; 1972 CB350K4; 1980 CX500D;1969 CB750.  Roadworthy: 1971 CB750K1
