Author Topic: Cross threaded one stud to header — advice?  (Read 586 times)
Offline gmoss
« on: January 01, 2022, 01:20:31 PM »
Repainted exhaust and repacked the baffle, cross threaded the very last nut I went to install.
Any advice on the best route to deal with this?
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Cross threaded one stud to header — advice?
« Reply #1 on: January 01, 2022, 01:43:18 PM »
Remove the stud and replace it.
You can either use a stud puller, or double nut the stud after chasing the thread a bit.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline gmoss
« Reply #2 on: January 01, 2022, 03:58:44 PM »
well i guess that's obvious enough, not sure what I was expecting. thx.
Online rotortiller
« Reply #3 on: January 02, 2022, 05:04:57 AM »
You could try chasing the threads with a die. Is it possible when the exhaust seats and is pulled in good threads will be engaged into the nut?
Offline Prospect
« Reply #4 on: January 02, 2022, 05:29:07 AM »
It would be next to impossible to put a die on it with the stud still in there. There's just not enough room. Pull it out using the double nut method and then run and die on it. It doesn't look that bad.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Online rotortiller
« Reply #5 on: January 03, 2022, 03:26:25 AM »
If it were me I'd remove the exhaust to gain access with a die or thread chaser (provided the situation suggests it can be saved) then use the best method to rotate the die with what I had on hand. It is best to remain positive and try the easy approach first before pulling the stud due to risk in snapping it off, in that case you will have a real access issue. The exhaust has to come off anyway.
« Reply #6 on: January 03, 2022, 07:56:00 AM »
 Vise grips if you can't get two nuts on it.
Offline Hoosier Honda
« Reply #7 on: January 03, 2022, 05:55:18 PM »
Could try a thread file with the exhaust off and out of the way, might clean it up enough to double nut it. I believe the pitch is 1.25.
https://www.amazon.com/CTA-Tools-8231-Metric-Restoring/dp/B00M9FZEQO/ref=sr_1_6?crid=3MKKWR0RYQT81&keywords=metric+thread+file&qid=1641261100&sprefix=metric+thread+file%2Caps%2C81&sr=8-6
