Author Topic: valve spring discussion?  (Read 3550 times)
« on: December 29, 2021, 09:44:30 AM »
 I'm curious if anyone measures valve spring tension? I have some old tech heads and a head or two with newer APE springs and retainers. I have the feeling our valvetrain is light enough to not require a lot of spring tension even at higher lifts but am thinking some of the old tech springs were serious overkill as far as spring pressure.
 A few years ago, I took an old head apart that had short springs, thick spacers and aluminum retainers. The last one had a retainer that was on the verge of failure, so I tossed all of it out.
  Was there ever an on head spring checker for the sohc engines?
Re: valve spring discussion?
« Reply #1 on: December 29, 2021, 11:24:34 AM »
My shop mechanic shim for 90 lbs if I have got it right. 6.6mm stemmed valves. (The 5mm valves less.)
CycleX has some numbers.
http://www.cyclexchange.net/Tech%20Tips%20Camshafts.htm
« Reply #2 on: December 29, 2021, 11:32:56 AM »
Think out loud Don…
What are you thinking?
Too much open pressure for the masses in motion..?
« Reply #3 on: December 29, 2021, 12:31:29 PM »
I forgot to mention if seats have been cut several times, maybe ex is sunken for valve to valve clearance. Thicker shims needed.
DP315 cam and 34/28 mm or 33.5/28.5mm valves are rather close.
It must be handy to have tool for measure the spring force.
There are experts on this forum that know all these details and much more. ;D
« Reply #4 on: December 29, 2021, 02:49:13 PM »
 I think this is an important function. Mike recommended 75lbs for my 550 race head. I have access to a spring tester and use on each assembled valve. I sourced different thickness shims plus with oem gives lots of selection. I check tension on every tear down, and replace springs every two seasons.
Shims can be slightly different for each valve depending on who does the seats. This is where experienced machinists help.
« Reply #5 on: December 29, 2021, 04:58:57 PM »
Think out loud Don…
  I regularly check the springs and monitor the lash on my race car and have seen problems with coil harmonics (cavitation?) and stack height too tall, these 750's seem pretty impervious to such issues.
  The 3 ported heads I recently bought have silver retainers (aluminum or Ti?) and RC engineering springs. One of these heads has before and will see some boost in its future.
  That fuels my desire to learn a little more about the springs we use.
« Reply #6 on: December 29, 2021, 05:42:13 PM »
Think out loud Don…
Back in late 70’s I saw some aluminum retainers (anodized)  all in excellent condition on an old 836 with RC cam and 12.5s..
Heard horrors stories of the same with the retainers pulling through…
On a tangent, the kibblewhite 33.5/ 5mm intakes are near 10grams lighter than F2 34s..
A miniature roller tip rocker may solve some of the observed upper 5mm valve guide wear and may relieve some valve stem flex with less than optimal rocker arm geometry..? Variable lash adjustment would be interesting..
PeWe has a good post on this 5mm bronze guide wear on his 392 head. I didn’t read whether he thought his rocker arm/ valve stem height geometry was spot on or not. It does read he’s move on to the stiffer 6.6mm stems and cast iron guides.
Makes a guy wonder when he’s sitting on a fresh stage 4 Rieck 5mm head…🤔
« Last Edit: December 29, 2021, 06:01:23 PM by Tracksnblades1 »
« Reply #7 on: December 29, 2021, 10:11:58 PM »
 I've set up the pushrod length on a big block chevy with nearly 7/8" of lift, that determines the sweep of the rocker tip over the valve stem.
  I can see where a high or low valve stem can cause our style of rocker to drag on it as it passes through it's arc. We just don't get to adjust much.
  I've been inside a few 750 motors and haven't seen a stock spring that broke, I have floated valves with an F2 cam in an old K head. It tagged one, I assume it was float.
« Reply #8 on: December 29, 2021, 10:22:24 PM »
 If you can find it, it's usually been gone over before. I even posted about my stupid BBC spring issue.
http://forums.sohc4.net/index.php/topic,44023.25.html
« Reply #9 on: December 29, 2021, 10:29:00 PM »
 It appears off engine spring check tools are what's available. I think I sold my old beam and pointer checker when I bought the LSM gauge type.
« Reply #10 on: December 29, 2021, 10:56:39 PM »
Think out loud Don…
My 5mm valve stem build was an old ported K6 head that earlier had F2 in valves and stock ex valves most of the time. No guide wear then during 50.000 km. Mild AF SS-1 cam.
Only soft mushrooming F2 valve stems solved by new valves and lash caps I got from Mike. Those valves moved to another ported K2 head.
The lash caps of the 5mm stem setup have marks centered which seems to be an OK geometry. But the design with the rocker arm is  bending.
I noticed that the 5mm stem valve setup was very soft sideways. Easy to flex sideways by pressing thumb.
This together with bronze guides. They survived 25.000km street use.
The guide wear was huge in the upper part of the guide.
Used cams DP315 with relatively low lift and 0.3mm lash, replaced by RC295.  About 50/50 use.
The 392 head replaced that head. It got stock guides and Kibblewhite 33.5/28.5mm valves. 104whp with that head on 970cc + 125-75 late October. (Better compression)
The K2 head made 101whp the year earlier on the 1005cc billet block. Probably more with thinner base gasket for higher compression as the last setup.
The old 5mm valve head is restored with CycleX iron guides and their shiny ss valves. I felt lucky to find 34mm inlet valves made for the head, no need to find matching blanks.
This head to be used on an 890cc build. Case will be bored to welcome the 77mm "sleeved" billet block just for sure.
CycleX guides and their shiny ss valves they got from a race shop sale is a possible low cost rebuild for 5mm heads. I have extra 34mm ss valves for the K2 head using F2 valves.
The 5mm valves are really light. No scale needed to notice the difference.
It must be a formula about the spring pressure depending on cam and rpm.
Really quick closing short duration +high lift+ high rpm must need harder spring setup, right?
My 104whp dyno had a max rev at ca 9500rpm. Max hp around 9000.
100whp 1000rpm earlier. So not much extra to shift later.
Offline Old Scrambler
« Reply #11 on: December 30, 2021, 01:02:03 PM »
I am not an expert............just experienced ;)
If you are measuring seated-valve spring pressure, what is the S-P at full lift? Should you change springs or use shims if you change cams?
I have had good luck with Bee-hive springs & Ti retainers in my race-motor. After watching the video showing Chevy valves bounce at less than 7,000 rpms, I investigated alternatives and found bee-hives to require slightly lower seat-pressures and more uniform pressure through-out spring compression with 410-lift. To me this means LESS wear and tear on the cam-lobes, rockers, and cam-bearings ;D
Standard double-springs and stock retainers have worked very well in these motors with modest tweaks for high performance apps.  I would strongly consider bee-hives for any maximum performance build.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #12 on: December 30, 2021, 01:22:10 PM »
Scram,
 Did the video show the beehives correcting the sbc valve bounce? Or was it just an informational one.?
Some old sbc cam grinds were known valve train killers…some good info came from these killers though…Even Killers can be ran with valve springs that don’t contribute to the Problem. As Don was pointing out on his bbc..
« Reply #13 on: December 30, 2021, 02:02:26 PM »
A long time ago, Crane Cams,  I believe used to write shorter valve springs that were shimmed to coil bind clearance at the installed camshaft’s actual max lift would result in very stable non resonating springs. Instead of a spring that could handle .650 lift installed in a .450 application that would never see anywhere close to coil bind clearance. At 10,000 rpms the retainer end of the spring is moving full travel @ 83.33 time a second while the other end sits on the shim. They used to compare the spring to a cylinder of water and a slinky at the frequency. Only place shorter may be better 😜
« Reply #14 on: December 30, 2021, 02:22:44 PM »
 This was killing my racecar springs. It took a cam change to set it all in motion, the engine had 400 runs on the previous springs then 30 and 32 before breaking them. We got around 300 runs out of the next set before the defect in the heads finally killed one. (Head) Now it's fresh again with about 40 runs on it.
   Edit, When that cam ate a lifter and my builder said comp couldn't/wouldn't weld it I was happy to get rid of it and lose its claimed extra 30HP.
« Last Edit: January 03, 2022, 08:13:18 AM by Don R »
« Reply #15 on: December 30, 2021, 02:40:17 PM »
Don,
Video worth a thousand
The Slinky CraneCams was talking about
Look how much clearance between coils at lift..
« Reply #16 on: December 30, 2021, 11:34:09 PM »
It would be fine with a list of spring setups for various cams and max rpm.
Then run with lowest pressure possible but still on the safe side.
KH cams more rounded profiles must be more valve train friendly.
« Reply #17 on: January 01, 2022, 09:49:48 AM »
Most NASCAR videos are considered reliable..........especially concerning valves and head-flow.
Some friends of mine (Mueller Bros.) decided to go racing at the Daytona 500 from the late '60s into the '80s. I occasionally watched and maybe handled a wrench when they would be working in their shop in Random Lake, WI. They always ran GM junk with a Pontiac grill ;) The home-built motors were never at top HP, but they usually finished the races. Depending on which cam was installed, the valve-springs were always individually checked for open and closed compressed pressure. In their later years of competition they sourced new springs and numerous other components from well-known teams. Those parts often had no manufacturer ID on the boxes.  I learned that the spring-material was very important to maintain performance to get to the finish line.
Today I observe that numerous beehive springs come in various colors and shapes. I suspect that not all are equal.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #18 on: January 01, 2022, 11:24:02 AM »
Yes, not highest hp but reliable build feels like a good idea. But where is the limit?
- Revs only?
- Compression with ignition OK as long as no pinging?
- Beehive springs act as progressive springs?
I had to search and found info
https://www.enginelabs.com/engine-tech/engine/beehive-springs-sound-great-but-will-they-work-for-you/
CycleX has for 5mm valves only.
It would be fine to know the lowest possible spring/seat pressure.
I have a feeling that my heads have a little bit too hard setting to ensure no float but add more wear.
Springs that can make valves to survive a missed gear shift. ;D
Need a video of an open CB750 setup with high speed camera that can show when valves goes wild.
Or which spring pressure needed for 0.400/0.375 lift, heavy valves and max 9500rpm. ;D
« Last Edit: January 01, 2022, 12:08:00 PM by PeWe »
« Reply #19 on: January 01, 2022, 11:43:19 AM »
- Revs only?
It would be fine to know the lowest possible spring pressure.
The comp cams article has a familiar read to a CraneCams publication 40+ years ago. No slinky comparison though.🤔
« Reply #20 on: January 01, 2022, 12:25:48 PM »
Tracksnblades1,
Good info about springs close to bind for stability.
I see now that you mentioned that earlier as found in the article.
The old RC springs were harder than todays springs from APE and Kibblewhite?
Or was it only the oldest version in need of valve cover bolt mod to keep the cam holder in place ?
I have one head with probably Action Fours springs I got in a build 1983 and used many street years, +parked for 20 years. Reinstalled with measured pressure a year ago.
« Reply #21 on: January 01, 2022, 02:21:42 PM »
Tracksnblades1,
You may be right. Back then some had the belief if a little was good a lot must be better. Think carbs..
RC was kinda the cutting edge back then in the square camshaft profile days and was limited to the springs material available. No cordial spring wire excepting aircraft perhaps... I’ve read somewhere also about the .050-.200 lift profile to predict how radical the profile for manufacturers to determine spring pressures required to keep the lifter/valve from ski ramping off the nose.
Don’s Spring Video sums up what CraneCams reference to a slinky motion.  A gram of intake valve weight savings used to be claimed to add 25 rpms to the max. Your 33.5/5mm intake will weigh 9-10grams lighter than your 34mm ss intake. Should allow for some of your missed shift concerns. I’m not sure whether that weight savings directly translate s to less/softer spring rates without cam profile considerations. Indeed an application video as you stated would be worth a 1000 also. May indicate what is causing the upper guide to funnel.
« Last Edit: January 01, 2022, 02:31:46 PM by Tracksnblades1 »
Offline johno
« Reply #22 on: January 01, 2022, 08:49:41 PM »
The springs have been the Achilles heel of cb 750 engines and builders in the 70,s & 80,s as we had to use what we could get and we didn't have a big selection to choose from as you suggested. Also as you suggested everyone played safe and run high pressure wether need or not. I also believe people felt safer running high pressures as our bikes had problems jumping out of gear and dropping valves was common. Very expensive exercise dropping a valve.  As we get older we realise the best person to discuss the spring pressures with is the cam grinder. All pro teams car or bikes have very good relationships with their cam grinders, its the best way to stay on top of the opposition. Like lots of other components these days the choice of materials is amazing ie spring wire material. The cam grinders can get very close to what is required after a chat. They talk in terms of rate of change in lift per degree of rotation to determine the pressure required to follow the profile. They not only understand the physics  but have computers that can run profile tests & simulations etc   The cam grinders have been invaluable to me in my days, find them , talk to them, trust them and after all that shop the market to get what you need.
« Reply #23 on: January 02, 2022, 01:56:28 AM »
About the cam profiles.
Each cam designed for a specific application.
The less agressive seems to have another power curve, wake up at higher rpms.
- Ex might be the most important? It open very quick and need to stay away from the piston when closing.
High lift, short duration harder life for the valve train. More power earlier but no need to rev after 9000rpm.
I have had thoughts about the steep closing on some cams. And possible need of springs that force valve to close that quick.
Even stock cam has rather steep close.
-The beehive springs more for the high rpm cams?
Some cam inspiration where some lobes look as rather soft for the valve train as the Action Fours SS-1 and the KHD
125-20 cam card IN lift 0.388", measured 0.380" when timed. (Cam data on internet IN 0.338")
Probably KH F
Super F has a very clear message in the instruction, absolutely not for street ;D
(Had no better photo.)
RC295 look a little bit more rounded than the 125-75.
DP315 actual lift rather low with recommended lash of 0.3mm. Running IN lift lower than the modest SS-1.
Less lash increase overlap rather much with power loss.
DP315 vs higher lifting RC295
OK, which seat pressure for each cam with rpm ranges and different type/size of valves? ;) ;)
It would be nice if time card could have those data
Edit:
Visited the garage and saw my 34mm valves on the shelf. The shiny CycleX 34mm ss valve is lighter than stock F2 34 mm.
The latter has got a backcut too, still heavier;D
It differ around 1.5-2 grams.
« Last Edit: January 02, 2022, 09:26:06 AM by PeWe »
« Reply #24 on: January 02, 2022, 09:00:13 AM »
  Thanks, the lobe profile pictures are interesting, I'll try to add mine to the mix.
 My KH "f" cam is clearly welded you can see the different metal from the side view. It works well on the street in an 836. (I also liked the Honda F2 Super sport cam though) I have a pair of RC315's now. Not a lot of guys around here did a cam swap for whatever reason. The stroker motor has an Engle cam in it, fairly aggressive from what I was told.
 The turbo motor had a stock cam as far as I can tell, I'm leaning towards the F2 Honda cam when it goes back together. The PO remembers putting stainless steel valves in one of the heads so I'll check that out too.
