Author Topic: Dual brake lines - No splitter/switch. Anyone have pics?  (Read 1025 times)
Offline timtune
« on: January 02, 2022, 04:35:07 PM »
I have a 76 750F and I want to eliminate the splitter/switch and run two lines from calipers to the MC. (will use a double banjo bolt with the pressure switch built into the end.
Has anyone done this? I'd love some pics to show how / where you routed the lines.
Thanks.
Offline eldar
Re: Dual brake lines - No splitter/switch. Anyone have pics?
« Reply #1 on: January 02, 2022, 05:22:53 PM »
No pics but I've seen a lot of bikes with that sort of setup. It looks kind of cluttered. Any reason you are ditching the splitter?
Offline Mag1
« Reply #2 on: January 02, 2022, 05:26:19 PM »
That’s easy to do, you just r.oute them the same way without the splitter, however what MC are you going to use? Since eliminating the splitter you also remove the switch. Unless you intend to use a modern MC with integrated switch from say Cbr600, or CBR 900 etc from 90’s onwards. Is this the info you need?.
« Reply #3 on: January 02, 2022, 06:34:13 PM »
Here are a couple.  Sorry about the blurriness and lack of detail.  You should be able to click on pic and zoom in.
js6VnF.jpg" border="0
js63gA.jpg" border="0
I used a master cylinder from late 80s/ early 90's sportbike that has a microswitch on the brake lever
« Last Edit: January 02, 2022, 06:37:44 PM by seanbarney41 »
Offline timtune
« Reply #4 on: January 03, 2022, 05:39:08 PM »
Eldar I thought the splitter and three hoses looked more cluttered than just 2 hoses running full length. Thanks for the pics Mag1. Any issue with the braided SS rubbing against stuff. I hear it's very abrasive. I can get the custom lines made with a vinyl coating but I like the SS look better.
Offline Kelly E
  • Geriatric Hooligan
« Reply #5 on: January 03, 2022, 05:42:18 PM »
We've done it several times. The double banjo bolt with the built-in switch will work just fine.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline timtune
« Reply #6 on: January 03, 2022, 05:44:27 PM »
Thanks Kelly. Got a supplier for that switch you could recommend?
Offline Kelly E
« Reply #7 on: January 03, 2022, 05:45:48 PM »
I think we bought it from Speigler.
1983 Honda CB 1100F
