Author Topic: Kick start lever hard  (Read 799 times)
Offline amitr0
« on: January 09, 2022, 06:44:07 PM »
On my motorcycle, I have noticed that at times the kick starter is hare, like it won't budge even when I tey my best to kick it, at others, it is easy as pie, I can easily kick start while seated on the motorcycle.
The bike runs fine, though. When it is hard to kick, I can easily electric start it.
But i am curious why this might happen.
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
Re: Kick start lever hard
« Reply #1 on: January 09, 2022, 06:55:57 PM »
What bike is this?
You say that the push-button starts the bike every time. Does it make any odd noise?
Offline amitr0
« Reply #2 on: January 09, 2022, 07:21:48 PM »
What bike is this?
What kind of noise? Mechanical or electrical(like motor whirring).
Either way, cNt remember anything out of the ordinary, apart from the stRter solenoid, which is normal.
It is a cb550k feom 1976
Offline minimo
« Reply #3 on: January 09, 2022, 10:14:13 PM »
As I recall, the kickstart assembly can be pulled from the 550 (you’ll want to lean your bike on its left side to keep oil from leaking). Or, you can get some visibility of it from below by removing the oil pan. It would be good to inspect the kickstart assembly perhaps on the next oil change. I think sometimes, the spring-loaded kickstart ratchet can get stuck in a position that might not allow for movement. Doesn’t sound like there’s any issue with engine turnover, right?
Offline amitr0
« Reply #4 on: January 09, 2022, 10:20:24 PM »
So far it runs fine, no loss of power, or funny noises, vibrations.
« Reply #5 on: January 09, 2022, 10:52:23 PM »
You may have found another reason the bike was off the road before you bought it or why the PO sold it...
Minimo has good advice on how to proceed. A Google site search with cb550 kickstarter spring search phrase should yield threads where discussion of Kickstarter spring issues have been discussed. CB550 Kickstarter removal might be another phrase to search on...
