Author Topic: I've got an 83' Honda XR100 'playbike' & looking for fork springs  (Read 1136 times)
I have this little 83' XR100 playbike and I want to put a set of aftermarket fork springs on it so that my 235lb self can ride it w/o bottoming the forks all the time;it has 27mm O.D. fork tubes with the stock fork springs which have had spacers installed in them to compensate & that helps somewhat.. They upgraded the forks on the 1985'+ XR100's and those springs won't fit my 83'.
I called Progressive Suspension,they didn't have them that small,so now I'm at a loss and wondered if there's some place that sells stuff for small playbikes and would have a listing for my 83' XR100 for a pr. of stronger fork springs.
A fellow told me BBR makes them,not sure if they'll be heavy enough?
« Last Edit: January 13, 2022, 01:13:39 PM by grcamna2 »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: I've got an 83' Honda XR100 'playbike' & looking for fork springs
« Reply #1 on: January 13, 2022, 03:12:23 PM »
Try RaceTech
« Reply #2 on: January 13, 2022, 03:47:09 PM »
Try RaceTech
Hi,I called them and they said they don't make them that small(17.5mm O.D.)of diameter.
Offline WhyNot2
  • I'm finally an
« Reply #3 on: January 13, 2022, 04:26:53 PM »
Hi, I'd like to see some pics of this bike......sounds like a neat bike.
Also, you could try a heavier fork oil to stiffen them up.
I've got a CB100, that I play in the back yard, to bruise ribs, when a little tipsy. (drunk)
I'm also rebuilding a CL100, haven't really figured out the type of final outcome. Maybe a town runner. Nothing crazy, I think.
« Reply #4 on: January 13, 2022, 06:49:34 PM »
Drill and tap the fork caps for Schrader valves, and pump about 15 PSI into them; my '82 Honda CR 480 and '82 Honda FT Ascot both came with air valves in the caps from the factory.
Online Alan F.
« Reply #5 on: January 13, 2022, 07:00:29 PM »
True. My CM400C had caps and a balance tube, spec was 3-11psi, so 1.5-5.5 per side?
« Reply #6 on: January 13, 2022, 07:35:08 PM »
I used to use air but found it causes a bit of stiction in the forks where they don't move as smoothly on my road bike.I have put-in up to 5 lbs. without a problem though.
« Reply #7 on: January 13, 2022, 10:25:11 PM »
Add distances inside to stiffen them up.
« Reply #8 on: January 13, 2022, 10:56:57 PM »
Yes,I have some spacers in there.
« Reply #9 on: January 13, 2022, 11:11:20 PM »
im with heavier oil,cheapest easiest thing to try.
« Reply #10 on: January 14, 2022, 06:52:17 AM »
I just ordered a set of fork springs that member here 'Alan F.' told me about;he must have had to do a bunch of searching to find them.They were on the Kmart website no less !  The dimensions to fit my application match and the price was great with free shipping.  ;) :)
Online Alan F.
« Reply #11 on: January 14, 2022, 08:33:24 AM »
They came up in a search for 17.5mm fork springs. I think K-mart is only online now and they'll sell you anything they can get their hands on just like WalMart.com.
Offline WhyNot2
  • I'm finally an
« Reply #12 on: January 14, 2022, 04:53:31 PM »
I'd still like to see the bike.........
« Reply #13 on: January 14, 2022, 05:21:43 PM »
I want to install heavier fork springs on two bikes.
The one XR100 I haven't actually taken possession of it yet but will be when I finish paying a friend for it.
The 81' CB125S which has the XR200R engine and front disc brake needs better springs also.
The bottom picture shows the bike w/o footpegs;I had just reinstalled the 185 engine and it was before I bolted them up.
« Last Edit: January 15, 2022, 06:40:17 AM by grcamna2 »
Online Alan F.
« Reply #14 on: January 14, 2022, 05:32:46 PM »
After finishing a few old projects I'll be doing a steering stem swap to add CB400T 33mm forks to a 250 Nigthawk. It's got a 310mm? drum now but I'll swap out the left fork lower for one from a CX500 so I can run the single disc & twin piston caliper with a pair of tubeless Comstars, I'll probably toss in some cheap cartridge emulators and look around at springs too.
What are those rear shocks Bill?
« Last Edit: January 14, 2022, 05:34:55 PM by Alan F. »
« Reply #15 on: January 14, 2022, 05:59:44 PM »
Hi Alan,that's a good thing,going over to disc:drum fronts just won't cut-it.
The rear shocks on this little 'mini-bike'  :D are very cheap(purchased from Wemoto UK $130 shipped)YSS shocks(13" eye to eye)made to fit a UK version CB125RS;they're a hair better in quality than OEM which were worn out.I prefer a better quality shock with what I carry on this bike,max load is 325lbs. & the rack will carry 65lbs+.This is my daily rider and a real workhorse,it even rolls on Interstates with me tucked out of the wind blasts.
I'm installing a black XR low miles dirt bike engine,fully rebuilt with more power this weekend;my powersports machinist did a Great job on cutting the valve seats for maximum flow.
« Last Edit: January 14, 2022, 06:02:24 PM by grcamna2 »
Online Alan F.
« Reply #16 on: January 14, 2022, 06:26:37 PM »
That's a lot of weight for a rear rack! Make sure to check it for cracks now and then.
Offline WhyNot2
  • I'm finally an
« Reply #17 on: January 15, 2022, 04:01:33 AM »
Wow.....nice. Like that rack.
