Author Topic: 82cb650 boggs down around 4500 rpm.  (Read 4070 times)
Offline harleyguywithahonda
Re: 82cb650 boggs down around 4500 rpm.
« Reply #25 on: January 31, 2022, 12:34:30 PM »
One more dumb question and I will stop wasting your time.
I am assuming the 4500 RPM  bogg is in 5th gear.  What is the highest RPM you can get to in 3rd gear?  And what speed is that
It boggs down in every gear I can get it to around 8 now in first, 6300 in second and from there it just goes down third is 6000 fourth is 5800 etc
« Reply #26 on: January 31, 2022, 12:36:50 PM »
3rd gear is around 6000 and about 35-40 mph
Offline 2wheels
« Reply #27 on: January 31, 2022, 12:43:40 PM »
I think you are on the right track check the ignition stuff.  Seems like you are loosing (or partially loosing) one side the the pickup - CDI module - coil    set.
Is there a gaping measurement on the pickups.   (dam -- i asked another question and promised i would not)
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
« Reply #28 on: January 31, 2022, 12:59:36 PM »
What I found did not mention anything about gaping the pick ups
« Reply #29 on: January 31, 2022, 01:09:59 PM »
I found a post on  another forum that says the pick up gaps should be around .4mm I stuck a feeler blade between the pick up and the cam and got .838mm I am going to try adjusting it.
« Last Edit: January 31, 2022, 01:11:49 PM by harleyguywithahonda »
Offline 2wheels
« Reply #30 on: January 31, 2022, 01:15:17 PM »
pick up gaping --  this guy did valves and pickup.  i have no idea if this is right
https://www.motopsyco.com/tag/pulse-generator/
« Reply #31 on: January 31, 2022, 01:41:52 PM »
Well I adjusted it to 0.4mm it didn't seem to make a difference. It definitely doesn't feel like a miss just like a surges when it hits the higher rpms. I'm really starting to think that I need to Jett it up again.
Offline 2wheels
« Reply #32 on: January 31, 2022, 02:11:04 PM »
It has the CV carbs, they can be finicky.  Try running with different amount of choke on and see the effect.
« Reply #33 on: January 31, 2022, 03:03:27 PM »
It's the metal slide style cv carbs half choke makes it worse
Offline scunny
  • don't call me expert
« Reply #34 on: January 31, 2022, 03:09:44 PM »
go the opposite way then, if the airbox has a removable lid take that off, if not remove the air filter and try it.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #35 on: January 31, 2022, 03:22:01 PM »
Did i read there was an accelerator pump in those carbs?
« Reply #36 on: January 31, 2022, 03:43:31 PM »
There's only the piece that holds the airfilter in, I have ran it with and without the air filter and it did not change it, buy I will try again.
« Reply #37 on: January 31, 2022, 03:45:25 PM »
There is an accelerator and it is functioning through all 4 carbs. The carbs number I'd is 44CATJ there's also a VB stamped on the side above the I'd number
Offline fizzlebottom
« Reply #38 on: January 31, 2022, 04:11:31 PM »
The troubleshooting guide in the FSM says that it may be the spark units, pulse generator, or spark advancer. If none of those are problematic, might even be weak/worn valve springs.
1982 CB650SC Nighthawk
2024 Kawasaki Z900RS
Online scottly
« Reply #39 on: January 31, 2022, 04:33:13 PM »
So I found a 78 cb650 manual online says I should have 530 plus or minus 50 ohms, my meter is reading 641 and 620 ohms for the coil resistance  on the pulse generator side of the harness and 159 ohms on the other side of the pulser coil plug oh and thats 641 for the yellow wires and 620 for the blue wires
If your meter is correct, than both coils are way out of spec. Is the bike running on a four cylinders? Do a "spit sizzle" test on the exhaust pipes. Also, have you looked at the spark plugs?
  • Holy Cow! I'm a
« Reply #40 on: January 31, 2022, 04:40:15 PM »
Has OP looked at the spark plugs?
If I'm interpreting your description accurately.  The machine bogs in the midrange, but surges in the upper rpms.  (That is assuming it does race to the redline)
Gives rise to wondering if the accelerator pump is over doing it.  There should be a proper setting described in the manual.  Could be contributing to a rich run condition.  Over rich until the pump is done and the motor gets back to its happy a/f mix.
Other possibility might be the slide rising too soon.  If someone tried to hot rod the cv carbs with a "spring mod" - that could also render moot the taper of the needle jet.
Further exacerbated by any back n forth working of the throttle causing the accelerator pump - to pump more.
Offline 2wheels
« Reply #41 on: January 31, 2022, 04:47:35 PM »
It boggs down in every gear I can get it to around 8000 rpm now in first gear, 6300 in second and from there it just goes down third is 6000 fourth is 5800 etc
Something makes me think this is important info in understanding what is happening.
Whether it is fuel or spark or valve spring or ?? , could one cylinder weak or failing do what is described above
« Last Edit: January 31, 2022, 04:53:54 PM by 2wheels »
  • Holy Cow! I'm a
« Reply #42 on: January 31, 2022, 05:21:11 PM »
Gear-dependent mapping isn't a thing on old bikes.
So its just that its not making power under load.
Doing a leak down test would be smart.
« Reply #43 on: February 01, 2022, 08:22:42 AM »
I'm checking the valves adjustment again today, I checked cam chain timing and it's right on. Is worn or weak valve springs a common issue on these?
« Reply #44 on: February 01, 2022, 08:25:26 AM »
I did try that and it is running on four cylinders, at this point I am also suspicious of the coils. I belive I read the meter wrong because it did say kohms, but it was also warm at the time i will check again today.
« Reply #45 on: February 01, 2022, 08:29:52 AM »
I have and they are generally pretty good looking but I will clean them and run them again to see, basically what happens is I will get to around 6000 then it just won't accelerate any more and feels like it just stumbles. It only red lines with no load I can get the rear wheel off the ground and run the bike through every gear and it will red line then just not when tire meets the road
« Reply #46 on: February 01, 2022, 08:33:09 AM »
Alright I will do a leak down as well
« Reply #47 on: February 01, 2022, 08:34:58 AM »
I am pretty sure it's getting fuel but something just isn't right and I can't figure it out yet, but like my name says, I'm trained in the old 2 cylinder harleys.
  • Holy Cow! I'm a
« Reply #48 on: February 01, 2022, 10:34:33 AM »
Thanks for a better description of whats going on.
I suspect the the slides could be lifting too soon.  At least, thats what was happening with the 750 triple i built.  The cv slides would jump to wfo in the midrange rpms.  Throwing off the fuel mix and turning the bike into a blubbery gutless pig.
You'd have to get an inspection camera into the venturi to see if thats the case with your 650.  Or take the airbox off.
Offline 2wheels
« Reply #49 on: February 01, 2022, 01:00:37 PM »
I was wondering if you could get one of those little cameras and stick it into the carb and watch the diaphragm pull the slide up.  Pretty much need someone sitting on the back doing the watching.
How else can you tell if the carb slide are acting properly?  Would a set of carb sync gauges tell us anything?
