Author Topic: I drilled out an oil seal.. What's the best quality RTV silicone ?  (Read 1463 times)
I had a fork seal that was Really jammed in a lower so I used(I thought I was being careful..)a small drill bit and left a tiny vertical 'channel' in the sealing area of the lower where the fork seal presses in on it's O.D.
I want to use synthetic fork oil and I think it might be good to use some excellent quality RTV silicone sealant along the outside of the new fork seal when I install it;hopefully it will seal w/o leaking.
What's a great silicone/sealant to use ?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: I drilled out an oil seal.. What's the best quality RTV silicone ?
« Reply #1 on: January 30, 2022, 01:49:57 PM »
Would be smarter to sand the area smooth and repair the damage with a touch of jb weld.  Then sand it smooth again.
« Reply #2 on: January 30, 2022, 02:06:16 PM »
I'm also considering using some crankcase sealant.
« Reply #3 on: January 30, 2022, 02:08:46 PM »
I've considered that since a few days ago and the more I mull-it-over,I'm not sure I could sand the i.d. of the fork lower(oil seal outer area)to the correct dimension w/o causing the possibility of a loose fit when i install a new seal..
  • Holy Cow! I'm a
« Reply #4 on: January 30, 2022, 07:27:16 PM »
It's not as daunting as it seems.
Remove the high spots, which you'd have to do anyway.
Fill the low spots with jb - then sand and feather that flush.
Either way, you don't want to glue that seal in place.  The service life on those is kinda short.  Eventually you (or the next guy) will be right back where you are now.
« Reply #5 on: January 30, 2022, 08:49:51 PM »
Consider Hondabond? It never gets super hard (or adhesive).
« Reply #6 on: January 30, 2022, 08:55:41 PM »
Yes,I am thinking that if I smear a bit in there after prepping/cleaning the surfaces to get them oil-free then install the seal.I think it may hold-up to synthetic fork oil.. I should probably let it set-up for a good 18hrs? before I fill it with oil.
« Reply #7 on: January 31, 2022, 05:29:33 AM »
I forget the timing on the tube.the stuff never really hardens up, so i’m sure the longer you wait the better. It’s also most effective when applied as a very thin film.
  • Holy Cow! I'm a
« Reply #8 on: January 31, 2022, 08:54:12 AM »
Not sure any of the tube sealants are meant for hydraulic pressure loads.  The seal setting into position on the downstroke could shear the bond.
Jb weld sets in 15 hours 🤷‍♂️
Offline Scott S
« Reply #9 on: January 31, 2022, 01:33:09 PM »
 I'd go with the JB Weld method.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Alan F.
« Reply #10 on: January 31, 2022, 02:05:21 PM »
+1 for the JB Weld
« Reply #11 on: January 31, 2022, 06:51:05 PM »
I think I can make a mini applicator 'stick' and try to fill only the small drill channel that I 'oops' on inside the fork lower seal area:it was only a 5/64" drill bit.  thanks  8)
« Last Edit: January 31, 2022, 06:52:59 PM by grcamna2 »
  • Holy Cow! I'm a
« Reply #12 on: January 31, 2022, 07:40:07 PM »
Popsicle sticks are an underrated tool 😎. I recommend the blue raspberry
Do try to deburr the area with a file first.
Offline Scott S
« Reply #13 on: February 01, 2022, 05:18:22 AM »
 The repair area doesn't have to be machined surface smooth. You can sand it enough that it doesn't nick or grab the seal. The seal does the work and seats tight against the fork leg.
'71 CB500 K0
'81 Yamaha XS650
« Reply #14 on: February 01, 2022, 01:00:52 PM »
I just picked up a fresh JBWeld today  ;)
« Reply #15 on: March 10, 2022, 09:19:38 PM »
I roughed-up the surface a little and applied JBweld to both spots where the small drill bit made two vertical grooves on either side,then after 36 hrs. to cure I carefully & lightly touched it with a Dremel as smooth as I could to keep the repaired area round  ::) then used a little fine emery to smooth it as well as possible.I also applied a light coat of HondaBond case sealer(just for insurance :D )to the outer edge of the seal and assembled it. No More Leak !  :)
