Author Topic: clutch shudder  (Read 537 times)
Offline blackbike
clutch shudder
« on: February 04, 2022, 06:35:11 AM »
After installing new clutchplates the clutch shudders quite a lot when I pull away in 1st gear. Any ideas anyone?
Verstuurd vanaf mijn SM-J600FN met Tapatalk
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: clutch shudder
« Reply #1 on: February 04, 2022, 07:00:07 AM »
Hard to say
What bike?
What clutch plates?
What oil is in the engine?
Is it adjusted correctly?
My K3 750 had a little bit of chatter early on but it went away.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline blackbike
Re: clutch shudder
« Reply #2 on: February 04, 2022, 07:20:20 AM »
Hard to say
What bike?
What clutch plates?
cb750 k1 (1974)
oem clutchplates
10w40
Re: clutch shudder
« Reply #3 on: February 04, 2022, 07:35:46 AM »
Did you soalk the new fibers in oil before fitting?
Offline blackbike
Re: clutch shudder
« Reply #4 on: February 04, 2022, 07:58:48 AM »
I did, but perhaps not long enough. Maybe should have left them overnight.
Will they soak up the oil whilst in the engine you think?
Re: clutch shudder
« Reply #5 on: February 04, 2022, 08:03:21 AM »
 Oil flows through the clutch hub they should get covered. You might try tying the lever back to let the springs relax the squeeze on the plates but that's just my non proven idea.
Offline blackbike
Re: clutch shudder
« Reply #6 on: February 04, 2022, 08:04:40 AM »
Good idea, I'll try just that! Thanx
