Author Topic: Hanging idle and carb adjustment  (Read 349 times)
Offline Bnomu
« on: February 01, 2022, 10:01:58 PM »
I have a CB500 which hangs at 2k then drops to normal-ish idle.
The #1 carburetor does not respond to the idle adjustment screw being turned all the way in, like the other carbs do.
The carbs were just rebuilt and I just checked the float level of #1 again.
All rubber is new and no vacuum leaks.
Thank you for your help!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Hanging idle and carb adjustment
« Reply #1 on: February 01, 2022, 10:28:24 PM »
Thats not the idle rpm adjustment screw.
We've been discussing hanging idle in another thread.  May want to scroll down and check that out.
