Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Hard to sayWhat bike?What clutch plates?What oil is in the engine?Is it adjusted correctly?My K3 750 had a little bit of chatter early on but it went away.
Did you soalk the new fibers in oil before fitting?
Oil flows through the clutch hub they should get covered. You might try tying the lever back to let the springs relax the squeeze on the plates but that's just my non proven idea.
