Author Topic: 1981 XV1000 TR1-project  (Read 35812 times)
Offline DME
Re: 1981 XV1000 TR1-project
« Reply #125 on: May 02, 2024, 02:25:44 AM »
Curious,they charge you by the pound or item,looks like they did a great job platimg that stuff. Is it getting really expensive to do like every thing else these days? How much did the rocker shafts grow by plating?
David
The rocker shafts has not been zincplated, nor has any other internal engine parts.
To zincplate a rocker shaft would be a really bad idea as the plating would not hold up for more than a second with a seized rocker as a result.
Also, all engine internals is covered in oil all the time so the rustprohibiting feature of zincplating is not needed.
Small parts up to 30 cm (12") are plated all together in a rotating drum which makes it quick and easy = affordable.
Longer parts will need to be hung and plated separately which makes it more labor intensive = more expensive.
This batch was a total of 4,5 kilos of smaller parts (run together in one drum), and one longer item that had to be hung separately.
Total cost of the zincplating (incl acid strip of old plating and postage to and from the platers 120 miles away) was 1150 sek, which is approximately $105.
Well worth it in my book  :)
« Last Edit: May 02, 2024, 03:50:53 AM by DME »
Offline DME
« Reply #126 on: May 05, 2024, 09:08:03 AM »
Reassembly has begun  :D
« Reply #127 on: May 05, 2024, 09:15:00 AM »
DME,those beautiful engine cases are So Nice;you might never get the finished bike out in the rain again,for fear of one bit of corrosion !!  ;D  8) 8) 8)
I'm glad you are assembling that 'Jewel' of an engine and looking toward when the bike is ready.  :)  ;)
Offline DME
« Reply #128 on: May 05, 2024, 10:05:48 AM »
Thanks, will hopefully look AND work good when completed  :)
« Reply #129 on: May 05, 2024, 11:12:13 AM »
Looking good!
« Reply #130 on: May 05, 2024, 08:57:15 PM »
Very nice work!
Offline DME
« Reply #131 on: May 11, 2024, 03:37:06 AM »
Bottom end is now buttoned up  :)
« Reply #132 on: May 11, 2024, 10:21:36 AM »
I like the design of your left crankcase;the front sprocket area of your Virago.
Offline DME
« Reply #133 on: May 12, 2024, 09:09:15 AM »
Always somewhat of a struggle to fit piston circlips and rings, and a damaged nerve that renders half of my right hand constantly numb doesn't help...
But hey, got there in the end and now the cylinders are fitted  :D
On to the heads...
« Reply #134 on: May 12, 2024, 10:31:16 AM »
I remember working on a guy's 1984' XV1000 Virago and it had some kind of flashy 'gold' plating all over it,from the factory at Yamaha.
I asked him if he or a previous owner had done that;he said it came that way from the factory.
« Last Edit: May 13, 2024, 08:30:10 AM by grcamna2 »
Offline DME
« Reply #135 on: May 13, 2024, 05:17:47 AM »
I remember working on a guy's 1984' XV1000 Virago and it had some kind of flashy 'gold' plating all over it.
I chose to have all steel parts yellow zinc plated.
Partly because of the enhanced corrosion resistance compared to clear zinc plating, but mostly because it will brake off from the silvery engine look from the vapor honing and will match my yellowed stainless exhaust and the planned paint scheme  :)
« Reply #136 on: May 19, 2024, 05:58:09 AM »
Beautiful engine. Did you carve the sproket cover open like that? Looks great!
Offline DME
« Reply #137 on: May 19, 2024, 11:40:19 AM »
Thanks, glad you like it  :)
And yes, the opening in the sprocket cover was cut by me.
Partly for weight reduction but mostly for estetics.
The stock TR1 runs a fully enclosed 630 chain drive that of course is great for chain life, but it really sucks in every other aspect...
This weekend was spent lapping the valves, reassembling the heads and fitting them to the engine.
Feels good to have the engine sorted soon  :)
« Last Edit: May 19, 2024, 11:43:28 AM by DME »
« Reply #138 on: May 19, 2024, 03:38:56 PM »
Feels good and looks GREAT!
« Reply #139 on: May 20, 2024, 07:56:14 AM »
Yes it does  8)
Offline DME
« Reply #140 on: May 21, 2024, 11:01:09 AM »
The engine is now done  :)
Just realized that somewhere along the way I seem to have forgotten that the bike I'm building is for offroad use...
Oh well, I'll just give it a wash once in a while  :)
« Reply #141 on: May 21, 2024, 08:01:45 PM »
The nice,smooth vapor blasted shine will allow dirt,etc. to slide off the surfaces of your engine.
Does this engine weigh more than 200lbs. ?
Offline DME
« Reply #142 on: May 22, 2024, 11:23:42 AM »
Good question, had to find out  :)
The hanging engine weighed 82 kilos.
The slings and front motor mount needed to hang the engine up weighed 1.4 kilos.
So the engine as pictured with no oil weighed 80.6 kilos = 178 lbs.
« Reply #143 on: May 22, 2024, 11:26:27 AM »
Do you use that sling to install it into the chassis ?
Offline DME
« Reply #144 on: May 23, 2024, 05:20:06 AM »
As the engine is a fully stressed member of the chassis, the reassembly is more a process of fitting all the different chassie parts to the engine, rather than fitting the engine to the chassis...
The white slings are just standard lifting slings, nothing special about those.
« Last Edit: May 23, 2024, 05:23:26 AM by DME »
Offline DME
« Reply #145 on: May 26, 2024, 06:11:34 AM »
Frame, swingarm, rear frame, forks and front wheel back on.
Need to modify a rear sprocket (one tooth smaller) before fitting the rear wheel, so that's whats next on the agenda.
« Reply #146 on: May 26, 2024, 06:39:45 AM »
Nice shots. Lovely build!
« Reply #147 on: May 26, 2024, 08:16:03 AM »
I see  :)
The engine/trans assembly is the 'Hub' of the motorcycle;as you said,everything else bolts on to it  ;)
Offline DME
« Reply #148 on: May 28, 2024, 09:47:55 AM »
Rear sprocket modified to fit the CB750 rear hub, and the weight is down another 116 grams  ;D
And so the onewheeler is now a twowheeler again  :)
Offline DME
« Reply #149 on: June 07, 2024, 11:05:08 AM »
Things are trundeling along as planned so far  :)
Since the bike has been tried and tested for two summers already, I'm in no rush to get it done.
I do quite enjoy sweating all the small things like the endcaps I found for the subframe tubes. The devil is in the details...  ;)
Also made a new arm for the rear brake plate that turned out 170 grams lighter than the stock arm. Not much, but a couple of grams here and there adds up along the way...  ;)
And now that the exhaust manifold I made out of stainless is back on, I'm even happier that i went for the yellow zinc plating as it compliments each other nicely  :)
