Author Topic: piston notch tool  (Read 1191 times)
Offline cbr954
piston notch tool
« on: February 24, 2022, 08:09:01 PM »
Anyone know where I can find a piston notching tool for the valve reliefs?  Standard stem diameter but 33.5 mm and 28mm valve heads.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline simon#42
  • liverpool
Re: piston notch tool
« Reply #1 on: February 25, 2022, 01:48:47 AM »
its called a milling cutter , not specific to pistons . check any machine tool supplier for sizes .
Offline cbr954
« Reply #2 on: February 25, 2022, 06:34:00 AM »
well i dont have a milling machine or a fixture to hold pistons so I was looking for tooling like what is available for larger engines using valve guide in head to cut the notches deeper.  Didnt know if they are available this small or not.
Offline Dresda500
« Reply #3 on: February 25, 2022, 06:51:39 AM »
In your case it's likely much cheaper to just braze a piece of tool steel to an old valve with enough overhang to give extra clearance radially. Simple and cheap. Even if you have oversize valves, the tool steel can overhang a few millimeters needed without concern.
« Last Edit: February 25, 2022, 06:53:18 AM by Dresda500 »
Instagram: hansrodncycle
Roadracing CB250K, Dresda CB500 and Martin KZ1000
Special intrest in hand made frames/bikes, porting/flowbench and Dyno tuning of vintage bikes
Offline simon#42
  • liverpool
« Reply #4 on: February 25, 2022, 08:16:56 AM »
have never seen a tool like that , you dont need a milling machine though just a drill , you will need to make a simple fixture to hold the piston though .
Offline Dresda500
« Reply #5 on: February 25, 2022, 08:26:07 AM »
I think he's talking this type. Back in the day, we would just have the shortblock assembled with all the pistons in the bores and use a dummy head and set on there with these type cutters. Before economical versions could be bought off the shelf we basically just made exactly the same thing, just with an old valve and some brazed on tool steel. You set your depth of cut by having a collar on the stem above the valve guide with the amount of clearance from collar to guide equal to the amount you wanted to shave off. Pretty elementary, but works a treat . Of course this meant disassembling a cleaning the crap out of your parts afterwards.
https://www.lindytools.com/ihpc
Offline simon#42
  • liverpool
« Reply #6 on: February 25, 2022, 09:31:03 AM »
that looks quite a good idea . not the way i would prefer to do it though . thanks for educating me !
Offline cbr954
« Reply #7 on: February 25, 2022, 03:45:16 PM »
Yes those are the type I was looking for but doesnt look like anyone makes them very small so I will have to figure out another way.  Probably hours on a dermal tool is my only option now.  Thanks for the responses.
Offline bear
  • Leeton in Australia
« Reply #8 on: February 25, 2022, 07:20:48 PM »
This is what we used. We would dummy up an engine and use the head for a guide to get angle and position spot on. It works a treat.
Offline Tracksnblades1
« Reply #9 on: February 25, 2022, 08:34:45 PM »
That’s all we have ever used..
The more accurate you braze and sharpen
the HSS cutters on, the easier it is on the
guides…😁
Age Quod Agis
« Reply #10 on: February 25, 2022, 09:39:00 PM »
On an already assembled engine, the trick was to smear axle grease around the top of the piston at the outside edge to prevent the aluminum chips from getting between the piston and the bore.
Offline Dresda500
« Reply #11 on: February 25, 2022, 10:32:54 PM »
Yes, good tip, then shop vac it out and be done with it!  If the OP doesn't have brazing capabilities but have an old valve, your local machine shop can surely help
