Our local Hydraulic Shop will make them.
They used to make the +6s, same guys older now,
are shortening them back to stock..😇
So, this post made me curious...hello, google...hydraulic shop Philadelphia...boom, there's a place 1.5 mi. from me. Called them up and they said bring over the lines and they can make them on the spot if they have the exact fittings. Worth a shot. I'm gonna dig up a set of old lines, figure out the new lengths and head over sometime soon. Maybe it'll all work out and I can support local business too. If not, back to the other options. Thanks!
Our local hydraulic shop supplies all types of hoses, fittings,
for the automotive, commercial, industrial, petroleum distribution,
agricultural, construction,manufacturing, rail, etc sectors.
Like B Danny points out, liability may limit many, sometimes more information is too much.
Besides economics, I don’t think you’ll find a huge difference from your local shop vs a specialty shop.
Similar to what Bryan posted AN fittings size… Here AN, JIC, flat face, split flange, inverted flare, etc,
fittings are all members of ANSI, SAE standardization.
I personally like a supplier that fabricates a few hundred a day and to pick it up the same day when possible.
But I don’t like a lot extra fittings to adapt something to make it work that same day vs having the exact and minimum required. California seems to supply the wholesalers all the odd ball one off, one in the USA, fittings, which is three days away here.
If the brake specialty shops mentioned above offer your exact needs and their quality is good. I think you’ll have several good options..
