I'm going to show my ignorance on this and just come out and ask...So On my Dresda the one big thing I'm missing is some decent carbs. When I got the bike it was missing the carbs on the race motor , the previous owner said they were special POSA or Lake style injector carbs and went on another race bike. So all I have really is a set of VM26 from a Z900 from what I can tell, 27mm ID on teh spigot and 26mm venturi, pics below. I will run a straight manifold so of course the spacing is all wrong...so my question to you racers that have straight manifolds...how do you deal with the funky spacing? I'll be honest I've never changed the spacing on a rack of 4 carbs before. I assume it would ential a new shaft and milling slots at the respective spots and then as well making a new back plate or modifying the old one with lots of cutting and welding...seems like a **it ton of work and these carbs aren't worth the time in my book...So is there a better set of carbs to start with? I know TG said he used some VM28 quite succesfully before going to CR29...But again to buy a set of used carbs, then modify...I'd rather just get a set of CR29 and be done with it, I know I'll end up with those anyway---but even on the CR carbs...can you order to the carb spacing of your liking?
I've got a full machine shop at my house, so mods are not an issue, but I have enough custom Items to build fo rthis bike, I don't need the busy work!!
Sorry for the newby carb questions...lots of info on making various fatory carbs work with the bent manifolds and various boot configutations, but haven't come up with much on this exact topic.
and what are you guys using for carb boots? Actual carb boots or silicon hose or?
Thanks in advance---If you ahve a set of CR29 you can't get rid of let me know...
