Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Looks like 72-76 CB750KScott
Chain guard mount I would imagine
Bend up a “U” channel of aluminum about 4” long. Bolt one end down and trim it so your earlier guard snaps into it..... should line up fine?
Not CB750 1976. (K6)It has a slightly different shape closer to where it is attached to frame. The grease nipple sit in the swing arm.But no problem to use a K2 swing arm on a K6. My blue K6 has a K2 swing arm.
