Author Topic: Chain oiler plug from Joker Machine  (Read 2218 times)
Offline jebon
« on: March 18, 2022, 08:33:15 AM »
I should have planned this better. The plug doesn't go all the way in for some reason. Not sure if it actually covers the hole. Anyone tried this?
"Don't let schooling interfere with your education"
CB750 K0 1971
Offline Alan F.
Re: Chain oiler plug from Joker Machine
« Reply #1 on: March 18, 2022, 08:43:49 AM »
https://jokermachine.com/products/cb750-chain-oiler-plug
Seems like a bad idea to potentially add that much silicone to your oiling system.
A chain saw spark plug is cheaper & short enough to fit under the cover & it comes with its own aluminum crush washer. I wouldn't trust a non-threaded plug held in with sealant.
Online PeWe
« Reply #2 on: March 18, 2022, 08:44:12 AM »
Probably need to remove the sinter metal plug with a triangle "washer"  under it. Both sits in the bottom of the oiler hole.
The plug with o-ring and triangle thing under. Only pushed inside.
https://images.cmsnl.com/img/partslists/honda-cb750k2-four-1972-usa-final-driven-shaft-drive-sprocket_bigma000039e21_674f.gif
« Last Edit: March 18, 2022, 08:50:06 AM by PeWe »
Offline jebon
« Reply #3 on: March 18, 2022, 09:19:22 AM »
Thanks.
I think I'll try and pull it again. I need to replace the swing arm bushings anyway. Maybe that'll give me a little more space to work it.
CB750 K0 1971
« Reply #4 on: March 18, 2022, 02:13:42 PM »
You do not want the potential or an oil passage blocking small chunk of silicone to break free and destroy your motor. Yank that sucker out of the motor and carefully pick out and scrape out every trace of silicone. Otherwise you might be rebuilding your 750 motor sooner rather than later...
« Last Edit: March 18, 2022, 05:28:40 PM by RAFster122s »
Offline jebon
« Reply #5 on: March 18, 2022, 03:35:13 PM »
Yes, that's what I thought too.
I just rebuilt the engine - too soon to split it again
Got the plug out. Will start scraping when the Hondabond is dry
Thanks!
CB750 K0 1971
« Reply #6 on: March 18, 2022, 05:26:44 PM »
Honda bond usually won't migrate unless you use a ton of it... And it is designed not to dry completely when between two sealing surfaces...
That's the issue with mechanics who go by the philosophy if a little is good a lot is even better. Your material needs for sealants should be small...or you are trying to solve a I'll fitting parts problem, this is a Japanese motorcycle by Honda, if you need more than a thin film your gasket is wrong and you shouldn't need much if any or non at all on most gaskets in our SOHC4 motorcycle motors.
Only the top cover is one which has a propensity for leaks and sometimes that traces to wrong sized replacement gaskets being used.
Be thankful you aren't dealing with a CX motor which incorrect gasket thickness can cause mechanical issues or early component failures. I am not talking about head gaskets either. A rear cover gasket that is too thin can cause a early stator failure a few learned because the stator moved too close to the flywheel because a thin gasket... The heat of a very hot summer day and high electrical load cause the copper of the stator to grow and the varnish or insulation coating of the stator was brushed by the flywheel and that cause the coating to crack and come off and vibration & rough roads lead to the copper wire coming free and a hot spot and then the wire moved and was shorting to the flywheel, stator failure!
« Reply #7 on: March 18, 2022, 06:45:43 PM »
Joker says "Then pound the chain oiler plug in place". ::) I made one that threaded in until it seated against the sintered (porous) plug, and used teflon tape on the threads. BTW, any sealant wouldn't get through that plug, and even if it did, the oiler is fed from the oil-air separator drain in the oil tank, not the pressurized oil system.
« Last Edit: March 18, 2022, 06:51:00 PM by scottly »
Online PeWe
« Reply #8 on: March 18, 2022, 11:26:16 PM »
That plug look good. ;)
All others I have seen are way too big and must be removed to get the sprocket on-off.
« Last Edit: March 18, 2022, 11:28:45 PM by PeWe »
« Reply #9 on: March 19, 2022, 01:01:10 AM »
That is pretty funny Scott!
Maybe you should make up a dozen of yours and sell them... Yours looks super clean...much better solution than the others.
I like the Teflon pipe thread tape, it shouldn't migrate if a bit gets cut lose what is the likelihood of any recirculating into the oil system? A chunk of silicone or Hondabond/Yamabond can circulate, if it works it's way back when the bike is turned off...
But blocking the port is going to essentially close off and make that branch fairly static and no oil will move into that feed from wherever it branches off.
Anyone got good cutaway drawings to illustrate the oil system. Ideally it might be nice to know the sizes of the case's oil passages.
Too bad Mike R hasn't made billet cases to go with his billet  block or he would have replicated the passages some how and done the homework to know the volume/pressures and therefore the sizes of those passages with some engineering experiments with calibrated volumes and pressures to do some mathematically calculations on a pump supplying X pressure by tapping into every port/line of a case he could determine the pressures of every area of the stock cases (sacrificing a set of cases to plumb in all these gauges...) by measuring the pressure of and operating motor with a new or rebuilt pump you have measured it's pressure and volume of flow in a scavenged set of cases you don't have to have a operating engine just part of a car or a jig to operate the pump in a fixture to measure it's std output at various rpms...
Then billet cases or a multiplane/multi-piece billet case could be designed as assembled cases ...using hard lines to carry the oil to areas that have cast oil feed passages.
I really cannot wrap my head around how they cast oil passages in a block that is cast...
Anyway...sorry for the segue into off topic and probably a hard but to follow...too much thinking out loud style writing... and writing a post on the mobile platform (phone,) is not conducive to re reading and seeing what you have written and editing it...
Ill shut up, good night...glad you have a plan on fixing your joker machine install.
Online PeWe
« Reply #10 on: March 19, 2022, 10:01:52 AM »
Cut a groove into Scottly's plug that match a std size o-ring should complete it.
Tighten it with a drop of weak threadlocker like Loctite 222 (purple) that does not allow it to come lose.
The 2 bolts holding the sprocket also get Loctite 222.
« Last Edit: March 19, 2022, 10:05:57 AM by PeWe »
Offline jebon
« Reply #11 on: March 19, 2022, 12:11:17 PM »
I started picking out some of the Hondabond but there's no way I can clean it out completely with the engine assembled.
I fitted the original "oiler" back in. My plan is to change the oil and drive it this season. The bike will be taken apart next winter for painting the frame.
Then maybe I'll split the cases and clean it up thoroughly. Btw I left out the oil tray when building the engine so I don't know why I even did this  :-\
If anyone sees this and considers putting in one of these, I don't recommend it unless the engine is apart.
CB750 K0 1971
« Reply #12 on: March 04, 2023, 03:14:20 AM »
Hey jebon did you do anything with this? How's your bike doing with the Hondabond in it?
Offline jebon
« Reply #13 on: March 04, 2023, 03:56:06 AM »
I didn't do anything other than crossing fingers
CB750 K0 1971
« Reply #14 on: March 04, 2023, 03:57:10 AM »
So still running good?
« Reply #15 on: March 04, 2023, 07:35:35 AM »
I don't like the "pound it in" part at all.
« Reply #16 on: March 04, 2023, 08:05:51 AM »
I don't either and will probably have a friend machine one out like Scott made that screws in.
« Reply #17 on: March 04, 2023, 08:16:23 AM »
 Wasn't the shade tree bush fix back in the day to pop a spark plug base in there ?
Offline Ellz10
  • ZZ
  • Knowledge is Power
« Reply #18 on: March 06, 2023, 07:48:10 PM »
I learned this the hard way, but learned it quickly, hah! Didn't make the same mistake again!
Well said Raf.
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« Reply #19 on: March 07, 2023, 09:45:44 AM »
I welded the oiler holes shut and used Honda Bond on the threads. Seems to be holding up fine.
« Reply #20 on: March 07, 2023, 06:11:11 PM »
Either that, or while the cases were apart to repair the chain damage from the untended chain, the little oil catch-pan inside the engine was just removed...
« Reply #21 on: March 07, 2023, 07:16:20 PM »
Yes the original poster Jebon mentioned in reply #11 he had removed the pan so the plug hassle for him was not needed.
« Reply #22 on: March 11, 2023, 10:18:12 AM »
 I had a can of left over hardware from a T250 Suzuki that spent a decade in a shed at a concrete plant with chloride. I already parted it out but this can of stuff was left over. Anyway, in it was a pair of plugs that appear to be the same thread as the cb chain oiler. Maybe I can stop some drippage in my older 750's.
« Last Edit: March 11, 2023, 10:40:04 AM by Don R »
« Reply #23 on: March 11, 2023, 11:18:36 AM »
Mostly, I just replace the rubber seal on these oilers, and then set it at 1/4 turn out. Then it only works at freeway speeds, and requires some chain spray when used in commuting service because the speeds aren't high enough to oil it.
The rubber seals can be replaced with 2 (or 3 if skinny) O-rings instead of the old rubber donut.
