Author Topic: 1971 K0 CB500  (Read 20031 times)
Offline Little_Phil
Re: 1971 K0 CB500 - fluff, buff, flip full motor rebuild.
« Reply #200 on: April 11, 2023, 02:16:34 AM »
Clocks on the early 500s seem to age better than later 550s etc., especially if low miles. You'll need to remove them and post a pic of them underneath out of the rubber cushioning to see the crimped ring.
Offline Shtonecb500
    • Youtube profile
« Reply #201 on: April 11, 2023, 06:42:23 AM »
duh, check if the ring was snapped, thanks for reminding me.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Shtonecb500
    • Youtube profile
« Reply #202 on: April 12, 2023, 06:13:07 PM »
I put 68 miles on it today, at the end of the evening I noticed white smoke coming from pipes 1 and 2, went to get gas and carbs 2 and 3 were dumping fuel under my bike. I haven’t revved over 5k while shifting and only hit 70mph accidentally once for a brief moment but immediately returned back to 60mph.
edit: went through the carbs cleaned the jets, gas tank, and petcock. No more fuel leak, nice idle, but still puffing white smoke from 1 and 2.
« Last Edit: April 14, 2023, 10:25:09 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #203 on: April 15, 2023, 06:54:10 AM »
After over a hundred miles on this thing it is really started to come to life - This thing has power EVERYWHERE - I can roll on throttle in any freaking gear and thing pulls. The right side fork gator cracked so I ordered a new set, when those show up Ill pull the entire front end apart and check steering stem bearings and replace fork fluid. If I had nice new rubber on this thing it would be a whole different story.
I was going to get new fork gators but I ended up buying a gently used set off ebay, hoping to get away with just replacing the broken on. Going to order new correct throttle grips and an MC rebuild kit, need to verify if the stock factory chain is still on the bike, and take new pictures.
« Last Edit: May 07, 2023, 07:26:01 PM by Shtonecb500 »
Offline Alan F.
« Reply #204 on: April 17, 2023, 08:11:01 AM »
Nice job!
Offline Shtonecb500
    • Youtube profile
« Reply #205 on: May 11, 2023, 05:01:20 PM »
Took the front end apart to paint the head light bucket, lower and top triple, speedo and tach mounting bracket, fresh grease on the steering bearings, new fluids in the forks and installed used good condition fork gators off ebay. 10 weight fully synthetic fork fluid went it, the original fork fluids still had some red to it and the seals were in good shape, even the uppers on the forks were in nice shape - usually very rusty under the fork ears. Polished the fork ears, handle bar, and mirrors a little more and I have some better condition signal stems for my K1 so they will get adopted to this bike.
Ordered an oem master cylinder rebuild kit and oem grips - didn't clear the triples and went with gloss on the lower and semi on the top. Degreased the steering neck. I'm painting the body work for 550 as well so the head light buckets will get wet sanded, sprayed black again, and cleared....will let sit over the weekend....the last picture is everything buttoned back up just waiting for the headlight bucket.
« Last Edit: May 15, 2023, 11:39:31 AM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #206 on: May 17, 2023, 03:42:32 PM »
Thankfully I opened up that master cylinder cause PO installed the incorrect rebuild kit, which is why he bought an aftermarket replacement M/C and slapped it on..happy the original came with the bike... that lever was flat for the first few mm of play and didnt feel right, bled the brake with new M/C and looking forward to see how it brakes n the future.
Painted the triples, top bridge, speedo and tach bracket, and touching up the gauge bodies with some black paint was all very, very worth it. Upon inspection the bezel on the speedo and tach are un-broken which means the faces were never rebuilt....SWEET, the chain is original
Finally got the number of a painter another local collector uses, If I repaint Im considering green. .
« Last Edit: May 18, 2023, 07:16:55 AM by Shtonecb500 »
Offline grcamna2
« Reply #207 on: May 17, 2023, 04:14:31 PM »
You going to keep' er after all this,right?!  :)
75' CB400F/'bunch o' parts'
Offline Shtonecb500
    • Youtube profile
« Reply #208 on: May 20, 2023, 07:17:56 AM »
its a coin flip at this point - if/when i need money this will be the first bike to go, I seem to keep chipping away at it even though i dont really want to.....it will be better for resale in the end tho.
Offline Shtonecb500
    • Youtube profile
« Reply #209 on: May 25, 2023, 06:37:01 PM »
« Last Edit: May 25, 2023, 06:41:26 PM by Shtonecb500 »
Offline grcamna2
« Reply #210 on: May 25, 2023, 08:01:34 PM »
How do you like how the bike is running and handling/stopping ?
Offline Shtonecb500
    • Youtube profile
« Reply #211 on: May 26, 2023, 07:05:08 PM »
before i rehabbed the front end the bike was running lovely, i have some air in my brake line so havent had interest riding it until i remedy that. Trying to wrap up the 550 right now.
Offline Shtonecb500
    • Youtube profile
« Reply #212 on: June 02, 2023, 08:42:53 PM »
got the bike when it had 4,077.3 miles on it, I got to about 4,180 when the engine damage occurred, and now we are sitting at 4,491.9 miles - 414 miles on tires from 1971....LOL
I rode the bike yesterday and had the idle set to like 900rpm and it did super well..I was told to take it up to about 1100rpm...all finished with the test riding, it starts runs idles and goes/stops, looks good, time to sell it.
the only thing im conflicted about is I know the bike could really shine if I rebuilt the wheels and put on new rubber.
« Last Edit: June 02, 2023, 08:45:57 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #213 on: June 07, 2023, 11:48:52 AM »
Just noticed these
« Last Edit: June 07, 2023, 11:52:16 AM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #214 on: June 07, 2023, 11:53:01 AM »
The bike did come from California, I’ll try to locate the original owner.
Offline grcamna2
« Reply #215 on: June 07, 2023, 12:09:23 PM »
I like seeing receipts like that,showing the PO's took it into the dealer  plenty and had it cared for.
Offline Shtonecb500
    • Youtube profile
« Reply #216 on: June 08, 2023, 06:37:47 AM »
yeah it should help with the listing...
Offline Shtonecb500
    • Youtube profile
Re: 1971 K0 CB500 - fluff, buff, flip full motor rebuild- COMPLETED
« Reply #217 on: August 27, 2023, 07:23:40 PM »
high res pics.
« Last Edit: August 27, 2023, 07:52:10 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
Re: 1971 K0 CB500
« Reply #218 on: November 16, 2023, 09:51:25 PM »
The bike is currently getting it's BAT listing revised for a no reserve auction.
Wish me luck.
Offline Alan F.
Re: 1971 K0 CB500
« Reply #219 on: November 19, 2023, 08:41:33 AM »
Good Luck. Don't sweat the wheels and tires, they're only original once.
Re: 1971 K0 CB500
« Reply #220 on: November 22, 2023, 04:57:02 PM »
This one looks exactly like my brother's 500. We toured together (me on my 750K2) for tens of tens of thousands of miles together.
I briefly had one of the same genre, but it was in the Brown color.
Offline Shtonecb500
    • Youtube profile
Re: 1971 K0 CB500
« Reply #221 on: November 28, 2023, 09:26:19 AM »
my first bike was a brown 73' cb500.
Offline Little_Phil
Re: 1971 K0 CB500
« Reply #222 on: November 30, 2023, 09:00:55 AM »
How do you like this one just up on UK ebay?  Approaching $14000!!!
3000 miles.
https://www.ebay.co.uk/itm/276200320629
Offline Shtonecb500
    • Youtube profile
Re: 1971 K0 CB500
« Reply #223 on: November 30, 2023, 06:58:00 PM »
thats a really nice one, hope these things start pulling in some good money
Offline BenelliSEI
  • 1969 cb750
Re: 1971 K0 CB500
« Reply #224 on: November 30, 2023, 08:40:20 PM »
Yours look perfect. Really lovely work.
