Author Topic: 1971 K0 CB500  (Read 17141 times)
Re: 1971 K0 CB500 - fluff, buff, flip/keep - blown motor rebuild.
« Reply #150 on: October 28, 2022, 02:32:21 PM »
If the piston is that chewed up I would wager the combustion chamber is as well, beyond hope.
Are you taking it to 550 size or keeping it a 500?
Offline Shtonecb500
    • Youtube profile
« Reply #151 on: October 28, 2022, 02:43:14 PM »
The original head is smoked and retired. I have my original 73' cb500 motor and the head is already stripped and degreased for rebuild, new pistons are 0.25 over.
« Last Edit: March 02, 2023, 10:09:01 PM by Shtonecb500 »
« Reply #152 on: October 28, 2022, 03:17:01 PM »
WOW, sorry to see that catastrophic failure damage, been there.
So was it spring failure, I dont quite understand how it happened?
Offline Shtonecb500
    • Youtube profile
« Reply #153 on: October 28, 2022, 04:57:29 PM »
if you are asking how the spring failed then my only guess would be from the heavy pitting in the springs and think that happened because the bike was stored with the pipes off of it for 30 years. The other springs are pitting the same way. If you are asking hhy the damage is so extensivead then thats cause I continued to run the motor even after I heard a noise.
« Reply #154 on: October 28, 2022, 09:32:31 PM »
Wow, this is a heartbreaker. :(
Sorry about that top end!
On an upswing note, though: you will pick up about 20%-25% more power for the bore job, and it will stay there in the future, not sap away like the original top end always does.
Can you tell if the pitting just caused spring failure, or was it debris jamming the valve movement?
Offline Shtonecb500
    • Youtube profile
« Reply #155 on: October 29, 2022, 06:28:41 AM »
based on what i remember about what i heard when it was all happening, I imagine the spring cracked but it all stayed in place. after another 14 miles maybe the keepers finally moved and the pieces of springs jumped around?
Im not sure, im not very familiar with the internal engine components, this is going to really be my first major deep dive into motor repair and understanding. Phil (mechanic) has not yet laid out what he thinks may have happened...so i can only paint the picture based on the noises i heard before it went south.
« Last Edit: October 29, 2022, 08:21:59 AM by Shtonecb500 »
« Reply #156 on: October 29, 2022, 12:28:54 PM »
I'm interested to hear what Phil tells you about what might have initially caused this.
Offline Shtonecb500
    • Youtube profile
« Reply #157 on: October 31, 2022, 12:39:32 PM »
stripped and degreased.
« Last Edit: March 02, 2023, 10:09:35 PM by Shtonecb500 »
« Reply #158 on: October 31, 2022, 01:44:20 PM »
Looking good.  8)
I hope you're able to wash the parts out multiple times and blow them out;that sand can really hang-on in unseen passages.
Offline Shtonecb500
    • Youtube profile
Re: 1971 K0 CB500 - full motor rebuild
« Reply #159 on: November 12, 2022, 10:19:40 AM »
I did wash it and hit it with compressed air a bunch of times, Phil does that again before he puts stuff back together.
Motor should be rebuilt before he goes to Florida in Jan....So i should have it all back together around then.
« Reply #160 on: November 12, 2022, 01:33:32 PM »
Did Phil decide to get this bike from you ?
Offline Shtonecb500
    • Youtube profile
« Reply #161 on: November 12, 2022, 05:34:21 PM »
you mean did he buy it off me? no he did not but he is doing the motor rebuild for me.
« Reply #162 on: November 12, 2022, 08:41:19 PM »
Ah ok,
I thought maybe he bought it from you and taking down to FL. with him.
Offline Shtonecb500
    • Youtube profile
« Reply #163 on: November 29, 2022, 09:18:36 AM »
Bottom end is complete and together, used all 4 rods from donor motor, all the bearings checked out ok so didn't have to replace any. Everything has been decked, head was rebuilt last week or so and all thats left is the bore job on cylinders. Should have the bike back together and running no later than end of the month.
Phil said its prolly gonna cost me 1k for everything, I can manage that.
« Last Edit: November 29, 2022, 11:30:40 AM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #164 on: December 05, 2022, 12:01:52 PM »
I was stripping the original damaged head and found the smaller inner spring was shattered as we
« Reply #165 on: December 05, 2022, 01:25:02 PM »
That's a good deal.
Offline Shtonecb500
    • Youtube profile
« Reply #166 on: December 05, 2022, 03:32:55 PM »
That's a good deal.
Ya he is for sure hooking me up. Had to order new set of rings as one broke, otherwise it would have been back together today.
Very very close. On another note, I finished taking the original head that sustained damage apart. Number 3 intake inner valve spring was shattered just like number one  intake, the main valve spring had not broken yet…..so so and three would have both been destroyed.
« Last Edit: December 05, 2022, 06:13:02 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #167 on: December 09, 2022, 06:57:20 AM »
MOTOR IS COMPLETE. Im too busy with work to get to the shop today so Ill have it all back together on Monday.
« Reply #168 on: December 09, 2022, 07:51:17 AM »
Just read about the broken ring. Frustrating, but you reminded me to change my order for my current build. I order 5 sets of rings. Guaranteed if I have an extra set on the bench, none will break!
Offline Shtonecb500
    • Youtube profile
« Reply #169 on: December 10, 2022, 10:12:14 AM »
 they were the single piece oil ring and he wanted to replace with the three piece anyway. My baby s back together and made whole. I’m gonna wait until Monday to throw it all back in the frame and should have it tuned by Tuesday.
« Last Edit: December 10, 2022, 01:30:40 PM by Shtonecb500 »
« Reply #170 on: December 10, 2022, 12:22:30 PM »
Congrats. All look great.
« Reply #171 on: December 10, 2022, 12:42:21 PM »
Nice work.  8)
That's Phil's place ? Great looking shop !
« Reply #172 on: December 10, 2022, 01:50:16 PM »
Very jealous of the shop space!!
Nice bikes
Offline Shtonecb500
    • Youtube profile
« Reply #173 on: December 11, 2022, 06:43:07 AM »
Nice work.  8)
this gives a better idea of the space, still lots more.
Offline Shtonecb500
    • Youtube profile
« Reply #174 on: December 11, 2022, 06:44:04 AM »
https://bringatrailer.com/listing/1972-honda-cb500-four-7/#comments-anchor
 original gold 72 just listed on bat
this is only the 3rd stock cb500 on BAT,  TOTAL..all others are modified.
this one is a transition model, has small gauges and large reflectors, large rear tail light.
it was originally a candy jade green before restoration, original odometer looks like it had around 7-8k original miles on the motor but faces were cracked, looks like they sourced oem nicer gauges with 80 miles on them. Body kit repainted, looks to have sourced an oem exhaust with rot in some spots on the underside, some coin size holes... I see some red gasket goop or something under the exhaust valve inspection cap..number 3 or 4.
« Last Edit: December 12, 2022, 04:35:08 PM by Shtonecb500 »
