Author Topic: Hose from brake flluid reservoir to rear master on 77 750F  (Read 898 times)
Offline jtb
  • An unlikely
« on: April 02, 2022, 06:25:19 AM »
I just rebuilt the rear master cylinder on my 77 750F.  The hose from the reservoir to the master cylinder is flared and split on both ends.  What kind of hose do I need to replace it?
Thanks,
John
1977 CB750F
1985 V65 Sabre
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Hose from brake flluid reservoir to rear master on 77 750F
« Reply #1 on: April 02, 2022, 06:52:13 AM »
Thanks,
John
does this help any?  find part number or dimension?  https://www.cmsnl.com/honda-cb750f2-750-super-sport-1977-usa_model491/partslist/F++10.html#.YkhUtTVOnIU
cb750 k6 - ugly
Offline bustech51
« Reply #2 on: April 02, 2022, 07:06:34 AM »
Is it the same line as a 1975 750F?  I believe it is.  If they are the same I have a sample one that I use to have copies made by a local hydraulic hose place for me.  Try taking yours into a hose place where you live and they should be able to make one for you.  Mine have all the DOT markings and look original.  Cost around $40-50 I believe. If all else fails I can have one made for you here locally and sent it to you.
Sent from my LG-H812 using Tapatalk
Offline jtb
  • An unlikely
« Reply #3 on: April 02, 2022, 08:07:48 AM »
I know the part number, it's unavailable.  I dont know the id size.  The fitting on the MC measures about 11 mm.  I'd like to take it somewhere to see if I can find a hose that will work, just was hoping someone would know the size.  Thanks,
1977 CB750F
1985 V65 Sabre
« Reply #4 on: April 02, 2022, 12:59:46 PM »
If you can get the details, order it here...
http://www.apexbrakes.com/custom.asp
Offline bustech51
« Reply #5 on: April 02, 2022, 02:45:14 PM »
I have a decent hose off a 1977 cb750F.  If you want I can take it off and go to my supplier and have one made up and then I can ship it to you.   All together it should be around the $100 mark.  Comes with all the proper DOT markings right on the hose.  This is what i have on some of my bikes.
Let me know.
« Reply #6 on: April 03, 2022, 09:27:28 AM »
No, that is a -410 part while the 75/76 is a -392 part
Offline bustech51
« Reply #7 on: April 03, 2022, 10:04:28 AM »
Since there is a part difference between the years, I can use the hose off of my '77 cb750f as my sample and have a copy made up.
Offline jtb
  • An unlikely
« Reply #8 on: April 05, 2022, 11:04:30 AM »
Thanks, All.  I just re-used the old one, trimmed it a little
1977 CB750F
1985 V65 Sabre
