Author Topic: Another issue with the Web 41A cam  (Read 3165 times)
« on: May 27, 2009, 08:04:31 PM »
They advertise .360 lift on both sides. With zero lash I get .330. I can understand -.005 to -.007 but on a new cam with 0 lash it's short .030???????????? Total BS. ??? ::)
Re: Another issue with the Web 41A cam
« Reply #1 on: May 27, 2009, 08:23:51 PM »
Duration is off too with lack of lift.....that thing isn't much better than stock IMO.
« Reply #2 on: May 27, 2009, 08:42:55 PM »
Must have been a Friday afternoon special. There have been a few of those, huh?
Offline new2novas
« Reply #3 on: May 27, 2009, 09:24:02 PM »
i had a feeling you would find that to be the case....you said they don't give you the card, is the cam even engraved with the grind on it....
i gotta tell ya, after being .015 too short, this is far from surprising
75 cb750F
« Reply #4 on: May 27, 2009, 09:27:35 PM »
Which cam did you get for me Mr Murphy ?
Sam. ;)
« Reply #5 on: May 27, 2009, 10:13:50 PM »
OK, fine. I'll get the Megacycle 125/70 regrind 125/75 then! dammit  ;)
How's the head? Not in a hurry, just curious  :)
« Last Edit: May 27, 2009, 10:15:41 PM by Jerry Rxman Griffin »
Offline Big Jay
    • CBRzone
« Reply #6 on: May 27, 2009, 11:20:50 PM »
Are you measuring cam lift or valve lift?  I forget what the Honda rocker ratio is.
Jay
« Reply #7 on: May 28, 2009, 04:30:10 AM »
Jay
Valve lift off the retainer......I was timing the cam
« Last Edit: May 28, 2009, 04:32:50 AM by MRieck »
« Reply #8 on: May 28, 2009, 04:31:24 AM »
Yes...the cam is engraved
« Reply #9 on: May 28, 2009, 04:35:15 AM »
Sam. ;)
A 63A I believe Sam
Offline new2novas
« Reply #10 on: May 28, 2009, 05:57:36 AM »
Sam. ;)
check out your post count *holds hand in air in metal type fashion and bangs head*
75 cb750F
« Reply #11 on: May 28, 2009, 08:26:32 AM »
Mike you probably have the thing buttoned up, but I wonder if you take the lift measurement at the lobe, if it could match what Web claims it to be. (maybe what Jay was getting at) I was given this reasoning before when questioning their magic fiqures. Maybe that is how they generate the data don't know. Easy enough to check in a 750 if you had the "play-around time"!
« Reply #12 on: May 28, 2009, 03:11:12 PM »
Sam. ;)
6,666, I'm a bit of a devil ;D ;D ;D ;D ;D ;D ;D
« Reply #13 on: May 28, 2009, 04:40:51 PM »
Sam. ;)
Sam....you have the 63B cam.
« Reply #14 on: May 28, 2009, 04:46:26 PM »
I can still do that Brent but lift at the valve is what is important IMO. The Megacycle cams I've put in (CB750's) pretty much match the actual valve lift. Web Cams I've used with shim/bucket desgins pretty much match the timing card lift too.
Offline MJL
  • Don't listen to me, I'm no
« Reply #15 on: May 28, 2009, 04:49:44 PM »
It'll probably be even less. In cars (don't know what Hondas are) the ratio is ~1-1.5 which means lift measure at the cam lobe is about a third of what you'd measure at the valve.
« Reply #16 on: May 28, 2009, 05:04:47 PM »
Agreed MJL, the rocker arm ratio should work to increase the lift at least. And what Mike says is true, determining clearances have to be done at the valve.
I'm just trying to find a way to throw support in WebCam's direction.  I know the quality of the product is good, just give proper fiqures in the first damn place.
Offline kghost
« Reply #17 on: May 28, 2009, 05:07:09 PM »
Not defending Web cams here...If mike measured it a believe him..
The one I got 3 years ago came with a card and was to spec....
Stranger in a strange land
« Reply #18 on: May 28, 2009, 05:13:30 PM »
In case it looks like I'm challenging Mike's fiqures that's not the case  ;D
I have both Web and Megacycle cams, the MC numbers were nearly spot-on, Web numbers were frustrating.
As I said the Web is a very nice product though.
« Reply #19 on: May 29, 2009, 05:13:07 AM »
If nothing else the lack of a timing card is bogus and unfathomable. Why not put a card in the box saying.....lift...yeah...it has some. Duration.....yep...duration is good....it should have some of that too. ::)
Offline kghost
« Reply #20 on: May 29, 2009, 11:22:53 AM »
Definitely...
Offline westfieldandy
« Reply #21 on: April 21, 2022, 01:39:39 AM »
Just wondering,   has anyone got the actual timing figures,   as I have a 41a here and the card has timing figures blank,  and I am finding differing figures, I have a card from a 341a which is different to the figures listed on webcams website,  and cycle x cx2 is supposed to be the same, so wondering what i should use
Offline Tracksnblades1
« Reply #22 on: April 22, 2022, 11:50:00 AM »
http://forums.sohc4.net/index.php/topic,50665.msg537438.html#msg537438
Beware: Seems to be some debate..as to lack of web’s split (asymmetrical intake exhaust)  timing.
« Last Edit: April 22, 2022, 11:53:47 AM by Tracksnblades1 »
Age Quod Agis
