Author Topic: New Project - 1972 Honda CB750  (Read 7447 times)
Offline God of Thunder
  • Trained to reign as the one!
Re: New Project - 1972 Honda CB750
« Reply #75 on: July 15, 2022, 09:47:11 AM »
Ordered new throttle/clutch cables today from 4into1. Can't wait to get these installed so my hand doesn't hurt!
1970 CB750K1
1976 CB750K6
Offline Phoenix
« Reply #76 on: July 15, 2022, 12:23:29 PM »
The spring may still be tight.  I tokk the spring off the carb and stretched it a little.  Do a little at a time remembering you can't unstretch.  Good luck.
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
« Reply #77 on: July 25, 2022, 09:23:34 PM »
Woooo! Yesterday I installed a new clutch cable and new throttle cables. The throttle has some play in it that I can't seem to adjust out - but its not terrible. Makes a HUGE difference while driving. We're getting closer!
1970 CB750K1
1976 CB750K6
« Reply #78 on: July 26, 2022, 03:42:55 AM »
Just a FYI on the throttle cables, it looks like you have them routed wrong. Do the throttle cables bind in any position when you slowly swing the bars back and forth from lock to lock? There shouldn't be any binding. I just installed a set of those bars and the short cable set from 4into1 on my K5.
It looks like you have them on the right side of the frame, the vin plate side of the neck? If so, they should go around the other side of the steering neck, on the left side of the frame, then in through the triangle behind the coils to the carb pulley. This is the way Honda originally routed the throttle cables. I'll try to get to my shop tonight after work and get some pictures.
Here is a link with a picture of the stock throttle cable routing(I downloaded the picture and attached it here, 2nd picture)
http://forums.sohc4.net/index.php/topic,20697.0.html
I've had a problem with the 4into1 short throttle cables on the pull cable with the adjuster locking nuts at the carb pulley being slopy loose to the threads of the barrel that when I tightened the nuts to lock it in place the second nut jumps the threads and won't tighten the cable. They sent me a replacement cable but it has the same problem of poor quality control in their manufacturing. I got it to lock somewhat by moving the second nut further backon the barrel to tighten it there and take up the slack up on the bar end of the cable. We'll see if it holds up with time but I'm not holding my breath......
« Last Edit: July 26, 2022, 03:45:35 AM by newday777 »
« Reply #79 on: July 26, 2022, 04:41:36 AM »
Some more reading about cable routing
http://forums.sohc4.net/index.php/topic,164060.0.html
« Reply #80 on: July 26, 2022, 08:31:16 AM »
 Well - that stinks.
1970 CB750K1
1976 CB750K6
« Reply #81 on: July 26, 2022, 08:41:01 AM »
 Well - that stinks.
Are they binding st any point in the swing of the bars???
« Reply #82 on: July 26, 2022, 11:26:57 AM »
 Well - that stinks.
Not in the few miles I drove it yesterday. But I'd still like them to be correct.
Additionally - these Handlebars. I got these from VintageCB750.com - it says "Stock Type Handlebar for the CB750K (1972) - Chrome. Drilled for wires like the OEM type.
Width 28 1/4" - Rise 3" - Pullback 4" x 7/8"Dia" - However when I look at other pictures of 72s, their handlebars seem to be taller than these. Am I missing something?
1970 CB750K1
1976 CB750K6
« Reply #83 on: July 26, 2022, 07:14:57 PM »
They are the European stock bars. USA had taller 4 or 5" bars.
