Author Topic: Help finding an O ring size  (Read 1144 times)
Offline exponent
  • Obsessed
« on: April 04, 2022, 12:08:18 PM »
Looking for an O ring that goes on the rocker covers for my 550. Part no is 91319323000. What are the dimensions? hoping to find some at Ace instead of spending $20 on davidsilver.
Thanks
'78 550K 2106630
Offline Alan F.
Re: Help finding an O ring size
« Reply #1 on: April 04, 2022, 12:53:47 PM »
I don't have the answer but the metric o-ring kit from Harbor Freight probably has the right size and it's under $10
« Reply #2 on: April 04, 2022, 01:05:36 PM »
Offline exponent
  • Obsessed
« Reply #3 on: April 04, 2022, 01:13:46 PM »
6x3, but I would buy the genuine Honda part.
$5.77 shipped.
https://www.ebay.com/itm/403375724094?epid=1723281461&hash=item5deb11163e:g:nEcAAOSwvRdhx3XY
I keep seeing the 6x3 but I don't know what that specifies or how to find other options with the same size
'78 550K 2106630
Offline Nurse Julie
« Reply #4 on: April 04, 2022, 02:03:17 PM »
$5.77 shipped.
6 x 3 = 6mm ID x 3mm Cross section.
Trust me I'm a Nurse, I promise it won't hurt....much
« Reply #5 on: April 04, 2022, 02:17:00 PM »
What do you mean by rocker covers?
Circular caps where you adjust tappets
Squarish end caps held by a screw
Cam cover above cam
Offline exponent
  • Obsessed
« Reply #6 on: April 04, 2022, 02:52:08 PM »
Went and bought the HF kit and it doesn't have the right size >:( and ace doesn't carry metric rubber. I'll keep searching
'78 550K 2106630
Offline exponent
  • Obsessed
« Reply #7 on: April 04, 2022, 02:54:35 PM »
Cam cover above cam
These red marks
'78 550K 2106630
Offline ozm29c
« Reply #8 on: April 04, 2022, 04:18:31 PM »
McMaster-Carr???
https://www.mcmaster.com/9263K717/
This is for a Viton O ring but there are other materials to choose from.
« Reply #9 on: April 04, 2022, 04:30:46 PM »
I think they are the 6x3 stretched to fit BUT the more common oil leak is the lack of soft alloy sealing washer between the steel angle bracket the end cap screws to and the cam cover
Offline Alan F.
« Reply #10 on: April 04, 2022, 07:35:31 PM »
I'm really sorry about that.
Offline Kevnz
« Reply #11 on: April 04, 2022, 09:42:22 PM »
Also, often the steel bracket faces that the washers ( upper and lower) seat on are mangled, so even if there are washers fitted, they don't seal well.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
