The SOHC/4 World Tour is in under way.
6x3, but I would buy the genuine Honda part.$5.77 shipped.https://www.ebay.com/itm/403375724094?epid=1723281461&hash=item5deb11163e:g:nEcAAOSwvRdhx3XY
Quote from: Stev-o on April 04, 2022, 01:05:36 PM6x3, but I would buy the genuine Honda part.$5.77 shipped.https://www.ebay.com/itm/403375724094?epid=1723281461&hash=item5deb11163e:g:nEcAAOSwvRdhx3XYI keep seeing the 6x3 but I don't know what that specifies or how to find other options with the same size
I don't have the answer but the metric o-ring kit from Harbor Freight probably has the right size and it's under $10
What do you mean by rocker covers?Circular caps where you adjust tappetsSquarish end caps held by a screwCam cover above cam
Quote from: Alan F. on April 04, 2022, 12:53:47 PMI don't have the answer but the metric o-ring kit from Harbor Freight probably has the right size and it's under $10Went and bought the HF kit and it doesn't have the right size and ace doesn't carry metric rubber. I'll keep searching
I think they are the 6x3 stretched to fit BUT the more common oil leak is the lack of soft alloy sealing washer between the steel angle bracket the end cap screws to and the cam cover
