Author Topic: World’s fastest CB750  (Read 4498 times)
Offline Vin750
« on: May 18, 2018, 09:08:16 AM »
Hi all,
We are looking to try to beat the record of the world’s fastest cb750 to celebrate the 50 years anniversary of the cb750.
We are looking go set the record within a criteria, there are many super highly modified bikes out there and if we go down that path there would be no limit (sort of) to what we could do to go fast.
The idea is to look stock and be as stock as possible inside and out. Some mods will be needed to unlock its full potential but we want to limit. But we will set a criteria.
-What are the known speed records for the cb750?
-Who holds the record or records?
-Where were they set?
-What was the criteria and how modified the bike was?
I have asked these questions in other forums and wasn’t able to get any solid info on what has been achieved so far. I guess these bikes are so much modified that there are all sorts of results out there.
Note that although I am happy to hear about drag records and speeds, I am interested in land speed records.
Thanks in advance
Offline Bob3050
Re: World’s fastest CB750
« Reply #1 on: May 18, 2018, 09:31:28 AM »
I think that the S.C.T.A. (Southern California Timing Association) can probably answer some of your records questions especially about El Mirage and Bonneville records.
Bob
« Reply #2 on: May 18, 2018, 10:04:22 AM »
Talk to Old Scrambler about his 2 Bonneville class records or better yet come out during the trials 8/24 - 8/30.
Talk to Bill Benton and Frank Loney about their drag racing records. They can also give you info about other 8 second 750s.
Then there's the late Russ Collins and his HIGHLY modified "750s".
Depends on your "criteria" I'd say.
« Reply #3 on: May 18, 2018, 03:07:49 PM »
If you can't do 125 at sea level on a GPS  you are wasting 500 bux entry money at Bonneville..
Offline robvangulik
  • Honda Fourever
« Reply #4 on: May 18, 2018, 04:01:10 PM »
I'm very proud of myself that I even knew where to look for this article after 36 years ;) , it must have impressed me at the time!
It is a "slightly modified" bike, but the numbers are quite awesome IMO.
Offline Bodi
« Reply #5 on: May 18, 2018, 05:47:15 PM »
There is no simple answer. Speed records have so many classes... which applies? The "fastest 750" would probably have had a fairing that hides most everything recognizable, or even been an enclosed streamliner. The SCTA and FIM have their records online. There are other bodies that do speed records but I think the FIM is the authority.
« Reply #6 on: May 19, 2018, 01:30:35 PM »
Fun information for us CB750 guys and those that plan to use a turbo.
A small detail.... article mention 64 mm stroke, should be 63 mm which give 998 cc with 71.0 mm pistons
Offline ivanhoew
« Reply #7 on: May 20, 2018, 03:02:42 AM »
maybe build it ,completely stock looking , go as fast as you can with it , then anounce its the
 "FASTEST STOCK LOOKING CB750 IN THE WORLD"
ad sit back and wait 5 nano seconds for the contradictions to start ....probably the quickest way to find if there is anything out there faster ?
just do it .
« Reply #8 on: May 20, 2018, 08:58:14 AM »
There was a pretty stock one raced at BONNEVILE,  3 yrs ago did not hit high speed.
 He came back 2 yrs ago and did much better, can't recall the speed. It should be in Old Scramblers B,Ville thread.
Both those guys ran that year and set some records.
 I think they took last year off.   Then a Triumph took back Old Scramblers record.
He now lives here in town,
 Old Scrambler is returning this year to defend his record . Some of us forum guys are going to cheer him on.
If you want to do this, attend, wether bike is ready or not, you can learn..
 Late  August. .. should be at least Old Scrambler, the Pharmacist, myself, and I hope more of us..
« Reply #9 on: May 20, 2018, 09:18:10 AM »
 Sorry but you guys are out of luck. I have the fastest cb750 sohc. Because that's what the PO told me. He seemed pretty trustworthy.
« Reply #10 on: May 20, 2018, 10:20:53 AM »
Frank, that was Mr Honda (real last name) from Japan on an ALMOST stock 750. I supervised the tear down since they weren't sure how to disassemble with their builder back home. 749cc with stock 392 head and a Yamiya Yosh Daytona cam. Nothing fancy. 125 and change. He brought it back as a 1000 and did ~ 130.
Offline robvangulik
  • Honda Fourever
« Reply #11 on: May 20, 2018, 10:42:43 AM »
I know, at that time at really could have been a TYPO ;D
Offline Mr Freeze
« Reply #12 on: May 20, 2018, 02:00:26 PM »
For the right price I'd be willing to ride my CB750 out of a cargo plane at high altitude to set the "fastest CB750" record. Vertical speed counts right?
Offline gschuld
« Reply #13 on: May 20, 2018, 05:37:46 PM »
http://clingonforlife.blogspot.com/2011/04/this-is-story-of-maybe-fastest-cb750.html?m=1
A bit out of the category of what you were likely looking for...but here it is.
Though is was considered a failure, it hit 305 mph. Twin cb750 engines, turbocharged.
George
Offline Vin750
« Reply #14 on: May 23, 2018, 04:19:51 AM »
Bob
Thanks, do you have any contacts I can reach out to?
Sent from my iPhone using Tapatalk Pro
Offline Vin750
« Reply #15 on: May 30, 2018, 12:19:31 AM »
Sorry guys I didn’t mean to neglect my own topic but for some reason I am not getting emails with updates when there is a reply here. The app I use on my phone isn’t alerting either.
Offline Vin750
« Reply #16 on: May 30, 2018, 12:22:52 AM »
Is Bill Benton located in Texas and is he the guy that sells parts on Facebook groups?
I am in Australia so going there for the trials isn’t that easy.
The criteria is to be as close to stock as possible. When we start modifying there is no limit to what it can be and the bike ends up very different to what it used to be.
Offline Vin750
« Reply #17 on: May 30, 2018, 12:24:14 AM »
I am glad you saved it, much appreciated. It’s almost my age. I will have a read.
Offline Vin750
« Reply #18 on: May 30, 2018, 12:26:33 AM »
Bodi, you make a good point. Putting a fairing to remove drag is less of a modification than completely different engine internals. I will look into this.
Excuse my ignorance but what’s SCTA and FIM?
Offline Vin750
« Reply #19 on: May 30, 2018, 12:27:43 AM »
Good point too, no better way to make people talk than with controversy.
Offline Vin750
« Reply #20 on: May 30, 2018, 12:30:41 AM »
I will consider that, certainly will be an experience to see all those people trying to beat records. I will look for this thread here.
« Reply #21 on: April 26, 2022, 10:29:06 PM »
 Are there any updates to some fun numbers?
