Author Topic: The Happy-ish Thread. Share your small wins and mixed blessings.  (Read 148426 times)
Online grcamna2
Re: The Happy-ish Thread. Share your small wins and mixed blessings.
« Reply #1750 on: December 12, 2025, 04:56:40 AM »
Despite the business of everyday life, I managed to lose some weight and get back into mostly fight shape.
Came back for my 7th pro fight. Won.
Now recovery and a lot of hours at work this week. Next week back in the gym and start on getting the garage ready to work in.
I hope you have heat out there.
Offline Kelly E
  • Geriatric Hooligan
« Reply #1751 on: December 12, 2025, 08:39:34 AM »
Nice job on the win Gurp. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline britman
« Reply #1752 on: December 13, 2025, 07:33:47 AM »
I did a much needed valve adjustment on a Flathead Harley Davidson 45 motor.  Since the bike was electric start and a three wheeler (Servi Car) I had to roll it back and forth to get to valve that you set the lash on.  With that in mind and considering I had to work from the garage floor since the bike lift was out, it took a while to get it done, but all needed adjustment and came back into spec after the hoop jumping.  Then came the fun part, screwing the two part valve tubes back into the tappet base, very fine threads, easily stripped that you need to hit just right to make them bite.  At the end of the first evening after trying for hours to get the last and most inaccessible front exhaust tube to screw down I walked away.  As I have aged I believe my patience level has increased.  Laying the tools down, going in having a good dinner, researching how others had approached the issue, and yes even saying a little prayer, made me have a new attitude the following morning.  I went back out with a hot cup of coffee, rechecked all the settings, and screwed all but the last uncooperative tube down.  After trying again for over an hour and I was just about ready to give up and look for ways to jury rig a clamp and rubber piece around the tappet base to prevent some of the leaking, the threads bit with just the right amount of pressure from a screwdriver and the tube locked down.  To me that is a feeling of accomplishment, sitting back and having the feeling, yep I won this one, and yes I did thank the man up stairs for his help. Probably going to take a while though for him to forgive the curse words that came forth on the two day ordeal. It is sometimes the little wins in life that make you really appreciate the big ones.
« Reply #1753 on: December 13, 2025, 08:16:42 AM »
Britman….. My favourite “special tool”. Take a break and do something else. Congrats on your win!
Online grcamna2
« Reply #1754 on: December 13, 2025, 10:51:05 AM »
+1 for the Win !
Offline Alan F.
« Reply #1755 on: December 13, 2025, 12:35:00 PM »
I just got my 25th ride in for "Frank's" 25 rides thread.
« Reply #1756 on: December 13, 2025, 12:49:34 PM »
« Reply #1757 on: December 13, 2025, 04:56:00 PM »
Well done! Just in time….
« Reply #1758 on: December 14, 2025, 12:13:33 AM »
 I was working on my gs1100's forks and left it on the floor just to get the exercise. While I was removing the fender bolts I realized I was sitting cross legged with my feet under me. When I was a service plumber, I sat on my shoes a lot to keep my knees and pant legs off of the floor as much as possible. I really didn't expect to be that limber again.
 Sometimes the lift leaves me standing but hunched over and it makes my back hurt.
Online grcamna2
« Reply #1759 on: December 14, 2025, 01:23:19 AM »
I used to sit/slide on my lift to work-in-close on some bikes.
« Reply #1760 on: December 14, 2025, 06:49:59 AM »
Don….. good for you! I recently started some clutch work on the cb750K3 and by the time I had it apart (on the ground), I quickly decided it needed to go on the left. I find if I get it at the right height (I have a short stool in the shop) work is easier. I still get lots on exercise getting up and down for tools!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1761 on: December 18, 2025, 09:18:23 PM »
I guess soon imma start working on getting the garage cleaned up between fight camps and get the "Poor boy chop" on the road. Its long overdue. Maybe get the gaskets for the shovelhead motor.  Going to buy the hardtail for "AlleyCat" at taxmas.
Not sure how much I'll get done with starting to fight again. The plan is 3 more fights. Make it to 10 fights as a professional with a winning record before I think of hanging them up.
Life stays busy. I feel busier and more tired at 35 than I dreamed of being at 25.
Here's to hoping 45 and 55 seen more time to enjoy life than 35!
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
