If you are going to park it all summer you may wish to put a set of substantial jack stands under all four corners and with the tongue on a block to support it. Basically get the tires off the ground. It will take a more substantial jack to do that, but you will be much more solid without the give… Just don’t try to do acrobatics in the trailer and knock it off the jack stands… haha
So, no swinging from the rafters, alright?
It is a good idea to cover your tires to prevent UV damage as well. Even Michigan has UV damage to the tires eventually. Down here the sun bakes the plasticizers and the ozone kills the rubber on tires that sit, then the heat does the job of finishing them off. That’s why my Vstrom didn’t get over 4000 miles on its original tires because the storage building would see 140-160F on hot days and we have had two record summers baking the snot out of my tires and motorcycles.
The sun here is brutal year round. No humidity outside of a rainy day , rare, or during monsoon season then the heat and humidity of 50-60% is awful. No humidity or moisture in the air to absorb the UV and you get burnt to a crisp easily by the intense sun of the southern latitudes of the SW AZ desert.
Fortunately, I have adjusted like most to avoid the sun and seek shade, so other than moving in day when I got a burn 2.5 years ago at the end of October ‘19 I have only had a mild sunburn maybe 2 times since.
Siesta and planning your day around avoiding the peak heat are the way to live in extreme heat and intense sun. I can’t stand visiting Phoenix when it is 120+ and it was those kinds of temps a lot last year. Here we had over 100 days of 100+ heat and I forget how many days of 105 or higher consecutively, records were set. Shaping up to do the same. I am trying to acclimate to the heat more this year and they think it is going to be scorching and dry for several years. Last year we had some record rain fall but is was all had in two months that were not consecutive and the ground doesn’t absorb a lot of water, so lots of flash flooding and runoff when we have heavy rains. Guess it is the price we pay for so much sunshine and nice weather in winter.
I’ll trade those things for what we have, having lived in temperate snowy regions of Ohio, NE TN and W NC for many years I prefer the hot dry heat.
Glad to see you working on the trailer and getting it prepped and repaired. Don’t be afraid to use Elastomeric roof coating on your exterior roof as it does a nice job reflecting heat and holds up for about 5 years for the cheaper stuff and can hold up longer for the more quality stuff. Helped friends apply it as we predominately have a lot of flat roof structures/houses and it is a common coating to use. White reflects the heat and it works well. Tile roofs are popular as are metal roofs, but the cost and expense of both… the bats can make homes under tile roof and it is a serious problem that is expensive to fix.
Ah, life in the SW…I love the desert.
Without a cooling vest 90F and above wouldn’t be possible to ride in the summer.
David
