Author Topic: Gas tank rust - opinions & testimonials needed  (Read 12490 times)
pyro139
Re: Gas tank rust - opinions & testimonials needed
« Reply #50 on: May 30, 2007, 01:24:59 PM »
Argh...  I'll see if I can find something at the hardware store to use instead of the Kreem stuff - probably just phosphoric acid anyways.
What can I do to keep it from rusting striaght away?  Fill it with gas?
grab a bottle two stroke oil and coat inside tank. that will keep it till add gas.
Offline .RJ
  • homebase in your airspace
« Reply #51 on: May 30, 2007, 01:51:49 PM »
Thats weird, I just had that idea a few minutes ago, and checked the thread now.
I'll probably mix it with some gas and slosh it around and should be good to go.
Offline kpier883
  • is quite the
« Reply #52 on: May 30, 2007, 04:30:24 PM »
Here is a link that I found.  It is an expensive option, but it might work.  My results with Kreem has been dismal, so I have considered this option:
http://www.gas-tank.com/bike.htm
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
geezer
« Reply #53 on: May 31, 2007, 09:11:34 PM »
Just a note:
On the '77. '78 750 tanks, the filler hole that sits at the bottom of the depression under the locking lid becomes the filler hole on top of a steep hill inside your tank when you turn it upside down to shake the drywall nails out.
Those 5 gallon tanks are a lot heavier than they look!
At least I got a pretty good upper-body workout as a result of my short-sightedness  :D
Oh yeah...
The chain can get inextricably tangled around the drain tube which runs right through the tank.
...think I'll try "The Works" bowl cleaner somebody recommended.
Offline .RJ
« Reply #54 on: June 03, 2007, 10:34:09 AM »
Home Depot had some phosphoric acid/metal etch stuff that I used to clean out the tank the 2nd time - I'm pretty sure it worked alot better than the 'Kreem', and filled with 3 gallons of gas mixed with some 2-cycle oil, and all is well for now.
