Author Topic: Yellow paint blobs  (Read 2699 times)
Offline greenjeans
  • 1972 CB750K2
Yellow paint blobs
« on: March 05, 2007, 07:12:59 AM »
So, the little yellow blobs of paint I'm finding on my 550 resto.... swingarm bolts, etc..  It's weird, I kinda like them, really seems to add a "fresh from the factory" look to certain areas.  Anyway, I'm sure some have been cleaned off this thing... anybody know where they should be?  And is it yellow or faded orange etc?  Thanks
Offline mick750F
Re: Yellow paint blobs
« Reply #1 on: March 05, 2007, 07:29:43 AM »
   It's yellow and as far as I know was done at assembly to mark a bolt/nut that had been properly torqued. A Honda tech that I used to use would mark them as he worked to preserve the factory look and to insure that everything he worked on was torqued to spec.
Mike
Glosta, MA
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #2 on: March 05, 2007, 07:46:19 AM »
Was also used by dealers when brought in for warranty work to see if bike had been taken apart. My original 550 has markings in the front rotor bolts, front brake banjo fitting, bottom triple tree cinch bolts, rear swing arm bolt, and front pivot for rear brake brake rod.
Fonda Honda
Offline grumburg
« Reply #3 on: March 05, 2007, 07:49:17 AM »
School bus yellow matches the best.
Fonda Honda
Offline mick750F
« Reply #4 on: March 05, 2007, 08:04:16 AM »
   Yellow nail polish works good too. Plus it comes with a nice applicator brush. ;)
Mike
Glosta, MA
Offline grumburg
« Reply #5 on: March 05, 2007, 08:17:47 AM »
Mike
Mike, won't ask why you have yellow nail polish on you bench. I guess it's because red can look trashy before 6:00.
Fonda Honda
Offline Raul CB750K1
« Reply #6 on: March 05, 2007, 08:29:40 AM »
Mike
Actually, I have white nail polish in my workbench. I didn't find anything better to restore my tank badges...
Offline spitfire
« Reply #7 on: March 05, 2007, 08:41:18 AM »
I  use the same system, after all the test fitting when I am happy I torque down and then put a dot of yellow paint on the bolt/nut, it shows me that I have torqued it down and it also will show clearly if anything works loose. I scale build models so am using Humbrol model paint (H24 Matt).
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Offline mick750F
« Reply #8 on: March 05, 2007, 10:15:42 AM »
Mike
   I tried the red and you're right, it made the bike look like a trashy French hooker. ;D ;D ;D
Mike
Glosta, MA
Offline mwohlenhaus
« Reply #9 on: March 05, 2007, 12:36:40 PM »
I noticed it on my k-6, but just assumed the po had wrecked and used junk yard parts to rebuild.  but now that I put some thought into it, it doesn't make sense that just the bolt heads would be marked if it were from a junkyard.
« Reply #10 on: March 05, 2007, 12:50:21 PM »
Some of the marks are anti-tamper one such as those made with Torque seal.
http://www.aedwis.com/torqueseal.html
These are the narrow ones like those found on the Brake components.
The wide ones were felt tipped paint pens, applied after the bolt or nut was torque checked on the production line.
http://opcompany.com/opco7.html
The marks on my 77 CB550F are still pretty well preserved and they are yellow.
« Last Edit: March 05, 2007, 12:55:55 PM by TwoTired »
