Author Topic: Is the frame open at the joints?  (Read 551 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: May 12, 2022, 08:17:31 PM »
Didn't know exactly how to word the topic title, but I'm curious if anyone who's cut these frames open can tell me  (I should've looked when I had my own back end cut off, but wasn't thinking) if the tube is open where they welded the joint - where I circled in the photo. And by "open" I mean that if someone desired, could they run wiring up inside the vertical/diagonal frame piece and then snake it to the left and run it thru the top horizontal frame piece?
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline newday777
Re: Is the frame open at the joints?
« Reply #1 on: May 13, 2022, 01:18:07 AM »
Having holes at the top of the frame is not a good idea as water can get in there and cause rust to form inside the frame then before you know it your frame is toast from the inside out.
Stu
My current rides
Prior bikes....
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
« Reply #2 on: May 13, 2022, 05:10:32 AM »
Just noticed a hole in a joint below the left side side cover.  There is some rust around the edge of the hole.  I was thinking about shooting some rust "stuff" in the hole.  Any ideas?
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Offline Bodi
« Reply #3 on: May 13, 2022, 06:33:42 AM »
There are drain holes or vent holes or whatever. You can squirt oil or WD40 etc in there if you want. Won't hurt anything. Do not plug them.
Offline Ellz10
  • ZZ
« Reply #4 on: May 13, 2022, 07:55:05 AM »
None of these replies are an answer to my question  ::)
Just to reiterate, I need to know if the joint there is clear.
Offline craz1
  • CDA, Idaho
« Reply #5 on: May 13, 2022, 08:32:13 AM »
I would say no, most of those joints butt up to a mother member. If I wanted to run a wire up that tube and then thru the top tube I would line up a drill just a bit bigger than the wire and drill through the top tube and into the lower vertical tube. What are you intending to do with the wire.
« Last Edit: May 13, 2022, 08:35:04 AM by craz1 »
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
« Reply #6 on: May 13, 2022, 09:02:30 AM »
  Straight tubes are usually open, but joints are not open inside like water pipe. Think of what was the quickest way to build it and that's how it was done. They did drill a tiny hole to allow the hot air to escape while welding in locations where the tubing could pressurize.
  There are re-enforcing plates available to weld around entry holes. NHRA requires them.
  Someone once said they would never ride a bike with wiring in the tubes. I asked about his handlebars.
Offline craz1
  • CDA, Idaho
« Reply #7 on: May 13, 2022, 10:21:42 AM »
Not sure why you would want to do this other than to clean up the look.
Offline Ellz10
  • ZZ
« Reply #8 on: May 13, 2022, 03:06:20 PM »
I was going to mount the battery under the swingarm and route the positive and negative cables thru the frame to the top tubes and then into the electrics tray for a clean simplistic look because the battery is too thick to mount in the tray while maintaining an electrics tray that ISN'T deeper than the 1" ofthe tubes so when I look at the bike thru the triangles head on you can't see the tray. I was going to originally mount the battery in the rear cowl, but then read on the battery that I can't mount/place it anywhere where there's no air circulating. So now I'm stumped.
Offline craz1
  • CDA, Idaho
« Reply #9 on: May 13, 2022, 05:38:27 PM »
You would have a very hard time(probably impossible) routing those cables through the frame.
