Author Topic: 78 750Foil filter housing  (Read 526 times)
Offline Handlebar
« on: May 17, 2022, 01:46:17 PM »
 The f2-3 housings are a 2 piece (base,canister) type housing. Question is will the earlier single piece housing work properly?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 78 750Foil filter housing
« Reply #1 on: May 17, 2022, 02:14:45 PM »
Yes, but use the bolt from the single piece oil filter housing. Don’t use the inner spacer on the bolt from the two piece F housing either.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Handlebar
« Reply #2 on: May 17, 2022, 02:25:00 PM »
That's good. I somehow can not find the housing for my F3 project.  Getting close to firing this thing up. Anyone have a housing and bolt they would part with
