Author Topic: CB 750 K0 running a tad rich - Questions  (Read 602 times)
Offline Scootch
  • Someday I'll know what I needed to know years ago
« on: May 21, 2022, 10:57:10 AM »
I think it might be running a tad rich but would like input. Please see the attached pic for specs regarding jetting. I don't know what position the circlip is at on the jet needles tho. Looking for some opinions on the jetting that is used. From the info I found those are the jets called for for a 1970 K0. I forgot to take a pic of the plugs. They are indicating just a little on the rich side...  TIA
Offline 69cb750
Re: CB 750 K0 running a tad rich - Questions
« Reply #1 on: May 21, 2022, 11:13:38 AM »
#120 and #40 are fine, be aware previous owners have drilled jets so you need to measure or compare with new jets and check air filter is clean.
Online newday777
« Reply #2 on: May 21, 2022, 11:36:59 AM »
Are you running  the Stock 300 exhaust and stock air cleaner?? Those play into the factors.
Offline Scootch
« Reply #3 on: May 21, 2022, 11:44:43 AM »
[/quote]
Yes running the stock 4 into 4 HM300 exhaust. Stock air cleaner.
Offline Scootch
« Reply #4 on: May 21, 2022, 11:49:16 AM »
Thank you for the reminder. That is a good point. The carbs are said to have been rebuilt but I do not have info regarding origin of kits/parts...
Online newday777
« Reply #5 on: May 21, 2022, 01:24:33 PM »
[/quote]
Well this new phone is driving me batty.  I can't get my pictures..... ugh
« Last Edit: May 21, 2022, 01:28:15 PM by newday777 »
Offline Scootch
« Reply #7 on: May 21, 2022, 06:25:29 PM »
Would be nice to know from a baseline tuning aspect someday for you in the future to know if you still have stock factory jets or questionable size aftermarket. Stock will have a stylized 'K' mark on them and usually can tell from the number stamping. Clean air filter is good and not an old dirty broken down old one. Can do some adjustments with the air screw but if its running well and not fouling plugs I wouldn't tear into it to deep. Those original airbox's are fragile and some of the early bikes ran a little rich anyways. I think Hondaman would suggest a Nippon Denso spark plug but not sure on the exact number off the top of my head. Its a 24 with some letters.  :D
« Last Edit: May 21, 2022, 06:27:21 PM by ekpent »
Offline Scootch
« Reply #8 on: May 21, 2022, 06:36:07 PM »
Thank you for the info. I agree with leaving well enough alone at the moment. It is running well. There is something to be said for if it ain't broke don't fix it...
Online newday777
Offline Scootch
« Reply #11 on: May 22, 2022, 05:37:21 AM »
Dead link here also.
Online newday777
« Reply #12 on: May 22, 2022, 09:14:49 AM »
Well I'm guessing this new phone didn't copy the whole link address 🤔
