Author Topic: Sometimes, they find you. 1971 CB500  (Read 10025 times)
Offline Scott S
Re: Sometimes, they find you. 1971 CB500
« Reply #125 on: June 04, 2023, 02:52:16 PM »
Uni filters are tough to not over oil and that leads to richer mixtures... Too much variability possible in oiling them.
Congratulations on getting it to idle nicely! Must make you really happy!
 I hear you, but I've used them for years without issue. Over oiling would make it rich and a hanging idle is indicative of a lean condition.  The mixture screws are at half a turn...also indicative that it was lean before.
 I dunno....it stumps me, and I've fought a similar issue on the last 3 or 4 bikes.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline grcamna2
« Reply #126 on: June 04, 2023, 05:25:26 PM »
Does the CB500 Four have it's idle air/mixture screws at the back of the carb throats ?
75' CB400F/'bunch o' parts'
Offline Scott S
« Reply #127 on: June 05, 2023, 12:53:12 AM »
 Yes, intake side.
'71 CB500 K0
'81 Yamaha XS650
« Reply #128 on: June 05, 2023, 06:09:49 AM »
Congrats
Offline BenelliSEI
  • 1969 cb750
« Reply #129 on: June 05, 2023, 07:03:49 AM »
Well done!
« Reply #130 on: June 05, 2023, 07:07:36 AM »
Happy ending, maybe more the possible start-up of a very good looking classic bike! ;D
Described problem with how to fix it will help others to find the root cause of a similar problem.
Offline Little_Phil
« Reply #131 on: June 06, 2023, 02:15:30 AM »
Well done, but it should bot be that sensitive to the pilot air screws. Been following this as my all original 71 500 also suffered the dreaded hanging idle. It is definitely just related to the carbs as I swapped them to another bike to work on them.
But I see the mirrors you have may be Honda, but not 500.
These are original.
Offline Scott S
« Reply #132 on: June 06, 2023, 12:21:48 PM »
 That's what I have.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #133 on: June 06, 2023, 04:14:24 PM »
These are original.
 You know what? I see the subtle differences now. But, I always thought that the HM on the mirrors meant they were genuine Honda.
 Are mine OEM?
 Either way, they fit and work a hundred times better than the aftermarket ones they replaced.
« Last Edit: June 06, 2023, 04:17:33 PM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
« Reply #134 on: June 06, 2023, 09:06:15 PM »
Great looking 500
