Author Topic: '73 CB550K0 Top End Ticking  (Read 1934 times)
Offline Scott S
Re: '73 CB550K0 Top End Ticking
« Reply #25 on: May 27, 2022, 11:25:17 AM »
I think I may have found it. The rocker arm on the side of the noise has a huge dent and crease on it! Maybe that's what did it?
 What did that cam lobe look like?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Little_Phil
« Reply #26 on: May 28, 2022, 01:03:29 AM »
And they share(CB500) the same problems you have now. Get for the newer cover. They are hard to find.
There was a service kit issued at the time,  12300-390-305. But include only the rocker cover and the pinned rocker shafts. Picked up one a few years ago from DSS.
Offline fritzer_108
« Reply #27 on: May 28, 2022, 08:27:25 AM »
Gotcha, well I did find a 1977 CB 500 head with the 4 shafts. It's on its way, and I do truly appreciate the help that you all gave! I'll be back if that's not the issue I suppose😅
1970 T120R
1973 CB750K3
1974 CL360
1976 CB750F1
1973 BMW R75/5
1973 Moto Guzzi El Dorado 850
« Reply #28 on: May 28, 2022, 10:36:16 AM »
There was never a 77 500 in the US. There was a 500 K3 model in Europe but not many of them
Offline craz1
  • CDA, Idaho
« Reply #29 on: May 28, 2022, 01:49:46 PM »
Probably means 550
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline Deltarider
« Reply #30 on: June 08, 2022, 11:28:44 AM »
All 500/550 will fit, only thre K3 model had the mod from the factory
My CB500K2 (ED, F, G) aka K2 GENERAL EXPORT (CMSNL) had the mod. There's only one way to find out yours has: write down your serial engine number and consult that particular page (Camshaft - Valve) in the appropiate parts list.
CB500K2-ED Excel black
Offline Remcod
« Reply #31 on: July 24, 2022, 06:27:57 AM »
I managed to acquire one but after removing the nut the valve axel holder screw wont come loose. Is it supposed to just drop out? Or is it a screw?
Verstuurd vanaf mijn SM-A415F met Tapatalk
« Reply #32 on: July 24, 2022, 06:37:32 AM »
Not sure why you need to take it apart, but it’s a tapered body pin that wedges in place.  I gave up trying to get one out, as the rockers were good.  Possibly heat the aluminum alloy cover and stack some nuts to protect threads on the taper pin and whack it with nylon or brass hammer.
Wound be a shame if the whacks caused damage to the cover, though.
Offline Remcod
« Reply #33 on: July 24, 2022, 06:56:36 AM »
Ok thanks, i was just curious if they would come out indeed to swap a tappet if need be, im gonna leave it as it is.
