Author Topic: Let there be light  (Read 513 times)
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
Let there be light
« on: May 27, 2022, 11:59:33 AM »
Question for Sparks:  Recently saw this in a bike blog.  He suggested wiring rear turn signals to the brake light for a grander response.  Is that doable?
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Offline 69cb750
Re: Let there be light
« Reply #1 on: May 27, 2022, 01:42:32 PM »
Install double filament socket, three tail lights, three brake lights.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #2 on: May 27, 2022, 02:41:22 PM »
Might want to use LED bulbs to lower current draw.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #3 on: May 27, 2022, 04:57:12 PM »
 Around here they need to be red if they are used as brake lights. That is a can-do thing though. It might require a trailer taillight separator.
   On my gl1000 I added drag specialties taillight/brakelights to the license plate frame and left the turn signals yellow.
Offline newday777
« Reply #4 on: May 28, 2022, 02:17:39 AM »
Yes it is doable. I did it on my brother's bike in 1976.
Get an extra set of front turn signals for the dual filament socket to replace the rear single filament lights and a set of red lenses to replace the yellow lenses so you don't have problems with the  LEOs or inspection laws.
If you really want to be seen, I highly recommend the P3 lights to add next to your sides of the license plate, they are LED that are intensly bright, they flicker in tail light mode to get attention of those behind you, flash in brake light mode and also there is an optional turn signal that also has 4 way flasher and tip over flashers.
I've followed behind bikes with them. They burn holes in unsuspecting blind cage drivers.......very impressive to get their attention. Not Cheap but very effective.
https://d2d-accessories.myshopify.com/products/p3-lights-rear-visibility-lighting-system-with-turn-signal-option-and-volt-meter
Stu
My current rides
Prior bikes....
Offline Deltarider
« Reply #5 on: May 30, 2022, 01:07:41 AM »
I'd rather stick to the original and have a level playing field. Once people enter the rat race, we may end up with even canons in the yard in stead of our innocent AR-15s.
CB500K2-ED Excel black
Offline newday777
« Reply #6 on: May 30, 2022, 01:40:32 AM »
Who is Sparks??
Stu
My current rides
Prior bikes....
Offline Phoenix
« Reply #7 on: May 30, 2022, 10:57:46 AM »
During THE war, they called electricians Sparky or Sparks.  No I wasn't in the war.  Just the Boy Scouts and ROTC.
Ed Spengeman
Indy
