Author Topic: 750A charge system  (Read 488 times)
Offline commander60
750A charge system
« on: June 10, 2022, 02:14:28 PM »
I bought 750A parts bike.
Will the rotor and stator fit a 1977 750K ?
Offline Alan F.
Re: 750A charge system
« Reply #1 on: June 10, 2022, 02:23:32 PM »
Yup. Seamless as far as ive read.
Online HondaMan
« Reply #2 on: June 10, 2022, 04:48:09 PM »
All you really need to change is the field coil. It draws about 0.25A extra power below 2200 RPM, but increases alternator output about about 1.25 amps above 3000 RPM.
Offline commander60
« Reply #3 on: June 10, 2022, 08:15:58 PM »
By the way, the diode plate looks a little different , kind of a flat design, worked ok.
Thanks
« Reply #4 on: June 10, 2022, 09:10:14 PM »
 I also wondered if there was any advantage to using the A rectifier and voltage regulator along with the alternator. I kept all of that and the wiring intact.
 I think that diode plate is mounted backwards on an A.
